Old 02-11-2017, 09:27 PM   #1
SLDPULR
SLDPULR's Avatar
22x11 20x8
Guys and gals! The time has come to lower my truck and choose my wheels. I have the style of wheel down and the size but not sure on the back spacing for a 22x11.
I'm going to go with the American Racing Daytona wheels. 22x11 in the back and 20x8 in the front. I was wondering if someone can chime in and tell me the offset for a 22x11. I can find it on the 10 inch wide but not the 11.
Also if anyone has and suggestions on tire sizes I would greatly appreciate the input and pictures. I'm planning on doing a 4/6 or 4/4 drop (I like a little rake)
1980 TURBO C10
(GRUMPYC10 ON INSTAGRAM FOR MORE PICTURES)
SLDPULR is offline   Reply With Quote
Old 02-12-2017, 12:03 AM   #2
bbbc10
Diggin The SquareLife
Re: 22x11 20x8
Those 22x11s come in a standard offest....they dont have diff ones.....try an go to their website....if google it
bbbc10 is offline   Reply With Quote
Old 02-12-2017, 01:18 AM   #3
Moose62
Moose62's Avatar
Re: 22x11 20x8
I did a 4.5/6 drop on a 79 big 10. 2.5" western chassis spindles and 2" coils, and belltech 6" flip. Truck is sitting perfect level. I also just put 20x9 all the way around. I went very different from the 99% of c10 guys, wider and larger front tire with 255/45/20 and I have no problems. I also studied the backspace for a long time and I think I'm right on.
I was more concerned with the front space as I cared more about getting tire closer to the fender, yet turn and tuck. And most all rims overall width measure 1" wider than the advertised inside dimensions. So my 20x9s are 10" wide, thus...
Front 20x9 bs-5.5" fs-4.5"
Rear 20x9 bs-4.5" fs-5.5"
After comparing my setup, and all the measurements I've seen on others. With a 20x11 you will need to push that wheel to the fender in order the clear the inner tubs. My wheel can, and others have done a 6" fs on the rear. So with a 20X11 at 12" wide and 6" of fs you will need a 6" bs. AKA 0 offset. But I would make sure someone here has done an 11" wheel, it gets tight on the backspace going that wide. As far as the front, I like mine I wish I had a 4.75" fs or even a 275/40/20, get the tire a hair closer to the fender or a little wider tire. I hate the skinny tucked in look, since I have no plan to bag it.
Moose62 is offline   Reply With Quote
