85 crewcab on a denali sub chassis
i have a 85 crew cab long bed Dooley i would like to cut the bed to fit a denali suburban chassis and make it single rwd. does anyone know where i could find info about this? thanks!
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113. 54 3600 Lincoln aviator chassis swap http://67-72chevytrucks.com/vboard/s...d.php?t=717927 |
![]() Join Date: May 2015
Re: 85 crewcab on a denali sub chassis
Got to start with wheel base and overall length.
Denali Suburban vs Crew Cab Dooley Wheelbase - 116" vs 164.5" Overall length - 203.9" vs 211.8" Then see how you are going to put a body that requires a 164.5 wheel base on a chassis with a 116" wheel base. Are you planning on making the crew cab a short bed dooley? Lot easier to section a frame then to add frame rail. And can you make body mounts? The suburban frame is dramatically wider than 80s frames. Give the google a shot or ask the guys at Pirate4x4.com - they are very accommodating. |
#3 | |
