Old 02-12-2017, 01:23 AM   #1
DMO
Disc brakes and boosters
I just finished installing disc brakes all around. I added brake booster and port valve. I have bench bled master cylinder and brakes lines but I can't build a firm pedal and when running the pedal drop straight to the floor. I can't find any leaks so I'm stumped. Any advice out there?
DMO is offline   Reply With Quote
Old 02-12-2017, 01:42 AM   #2
Captainfab
60-66 Nut
Re: Disc brakes and boosters
Did you get good fluid flow from the bleeders on all 4 calipers? What calipers are you using? What master cylinder? What booster?
Old 02-12-2017, 01:51 AM   #3
DMO
The calipers in front are from LMC truck, rear are a conversion kit from Summit. The booster was given to me by a friend so I'm not sure on that one.
I did get flow from all bleeders. Stronger flow in the front than the rears
Old 02-12-2017, 01:59 AM   #4
DMO
what do you charge for the booster mounting bracket? I will take some pics of what I have done tomorrow to show what I have done and if you can make any suggestions. Thx! Dan
Old 02-13-2017, 01:12 AM   #5
Captainfab
60-66 Nut
The price is exactly the same as in post #1 of the for sale thread.......link is in my sig line \/ \/ \/
If the rear calipers are not flowing much, the valve inside the combo valve may have slid over and blocked the rear circuit. It will need to be centered again.
Old 02-13-2017, 11:10 AM   #6
jweb
jweb's Avatar
This may not be your problem but there is a tool you need when you are bleeding your brakes for the proportioning valve.
https://www.performanceonline.com/Co...ve-Bleed-Tool/
jweb is offline   Reply With Quote
Old 02-13-2017, 12:48 PM   #7
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
DMO, this is from my Master Power Brakes literature, may help if what Captainfab is saying is the case:
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-10-2017, 10:35 PM   #8
DMO
Thanks to all for the help with this. As it turns out the MC is leaking and has to be replaced. Here is the problem I don't know the type of booster I have. It's a short pocket booster but that is all I know. I know I need a short pocket MC but any suggestion on bore size?
Old 04-11-2017, 08:18 AM   #9
zach_carver
zach_carver's Avatar
Im having the same issues.. What kind of master cylinder are you using? Very aggravating I know. Mine is fine until I start the truck then pedal has little to no resistance and goes to the floor.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 04-13-2017, 07:31 AM   #10
fleetsidelarry
Senior Car Nut
DMO-did you get it figured out?
Larry
Old 04-13-2017, 02:28 PM   #11
Moarplease
Don't forget to correct the pedal ratio when adding a booster to a previously manual setup.
Adam
Moarplease is offline   Reply With Quote
Old 04-13-2017, 04:38 PM   #12
statenine
statenine's Avatar
I think typically a 1 1/8" bore is recommended when using a power booster. Thats what the guys and CPP told me anyways
statenine is offline   Reply With Quote
