Old 02-12-2017, 02:10 AM   #1
taclem
taclem's Avatar
292 to 327 swap
I am pulling the 292 out of my 66 and want to install a 327, with a Saginaw automotive 4 speed. What do I need for motor mounts, can I move one side of my mounts? Will the clutch setup work OK? Thanks, taclem
taclem is offline   Reply With Quote
Old 02-12-2017, 02:18 AM   #2
62stepside longbox
62stepside longbox's Avatar
Re: 292 to 327 swap
Your passenger side motor mount will need to be changed, the drivers side should work fine as well as your Bellhousing, but I'm not 100% sure on the clutch
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-12-2017, 11:19 AM   #3
dracko
dracko's Avatar
Re: 292 to 327 swap
Everything for the clutch should still work, I just swapped a 230 for a 327.
dracko is offline   Reply With Quote
Old 02-12-2017, 01:22 PM   #4
padresag
Re: 292 to 327 swap
you will need the passenger side frame perch from a 230, 250 i6 or a 283 63-66. for the clutch linkage you will need the threaded ball stud engine side for a sbc. yje i6 uses a pressed in ball stud on a bracket/ you cannot use that one
http://www.persh.org/pickup/perches.htm
ron
padresag is offline   Reply With Quote
