Help with air cleaner/ valve covers!
Hey everyone, my goal is to buy a newer edelbrock air cleaner to replace the stock one. I would also like to buy newer valve covers. Is it possible to eliminate some of the hoses that run from the valve covers to other things? Hose #1 runs from the driver's side valve cover to the neck/ ring between the air cleaner and the tbi unit. Hose #2 runs from the factory air cleaner to a crankcase breather (I think). Hose #3 runs from the passenger side valve cover and goes to the front of the tbi. Any help would be appreciated.
1987 K20 355/465/208 1988 K30 6.2/400/205 |
Re: Help with air cleaner/ valve covers!
Did you ever figure this out?
I see it was posted last year and I am currently doing the same thing. Thanks |
This might help a little. Mine is a carb system. Guessing a bit on OP hoses as no sizes were included.
3/8" hose from drivers side to front of carb base. Connects to the Positive Crankcase Ventalation(PCV) valve. Guessing is Hose #1 in first post but could be #3. Larger hose, roughly 1", from air cleaner housing to passenger side cover. Air filter side of PCV system. Connects to a small air cleaner inside the main air cleaner housing. Guessing Hose 2 from first post. A normal PCV system pulls air into one side of block through the air breather filter and sucks it out of the opposite side through the PCV valve. The small air filter is inside the main filter housing to handle cases where there is too much blow by for the PCV valve to handle. That allows any excess fumes to be sucked into the carb/tbi and burned with the normal fuel/air mix. You REALLY want to keep a functional PCV system. It does a lot to keep your engine oil moisture free and is also one of the most effective emissions systems with minimal performance impact. Removal can harm performance as the system is tuned for the extra air. |
