Old 02-13-2017, 05:19 PM   #1
Robert555
1970 K2500 needs new rear axle
Hi. My 1970 GMC 3/4 ton 4WD pickup has a 4.10 Dana 60 rear axle that has significant damage to one of the spindles, so I need to replace it.
I know the 2WD rear axles are different, but what exactly is the difference between the 2WD and 4WD rear axles on this truck?
I'm also thinking about maybe upgrading the rear axle to a later model 14 bolt. Exactly what years and model trucks should I be looking for to do this?
I'm a welder so I don't mind fabricating spring perches, etc. if I have to, but does anything just bolt in?
I don't really care one way or the other about disk brakes. What is REALLY important to me are good parking brakes. Is there any difference in holding power of the disk brake rear end parking brakes vs. the ones on drum brakes?
Thanks for any help!
Robert555 is offline   Reply With Quote
Old 02-13-2017, 06:03 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 1970 K2500 needs new rear axle
Welcome! I am still running an Eaton HO52 in my '72 K20. Unless you have a good one lying around, you probably won't want to swap to one of those. About the only input I have is..... I am pretty sure drum brakes will hold (as a parking brake) better than discs. Many disc brakes use a small drum as a parking brake. Full-size drums should hold better. IMO, that's the only advantage drums have over discs.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-13-2017, 06:53 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
73+ 1 ton 14 bolt srw is a bolt in minus moving a shock mount. All other 14 bolts will need perches moved and shock mounts as well.
Tyler
57taskforce is offline   Reply With Quote
Old 02-13-2017, 09:26 PM   #4
davepl
davepl's Avatar
Yes. A disc brake rear end has one of two setups:
- A mechanism for grabbing the disc via the caliper, ala Cadillac, but they don't hold well
- A drum inside the rotor hat
I prefer the little drum inside the hat, but it's a lot less surface area being grabbed than by drum brakes.
Unless you're going to road-course the thing or tow in the mountains, I can't think of any reason I'd mess up a good system to do rear discs. I've generally regretted it when I've done it, and now run drum/disc in most vehicles.
My C2500 has the D60 as well, I'm also curious as to what the difference is 2WD to 4WD.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-13-2017, 09:52 PM   #5
57taskforce
All about them K’s
2 wheel leaf spring trucks use different perch locations for one thing.
Tyler
Old 02-13-2017, 11:02 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 1970 K2500 needs new rear axle
let me check with a buddy of mine to make sure he still wants the one i have. if he doesn't want it, i'll make you a hell of a deal on it. i'm only a couple hours from you so you can come pick it up. it came out of a 71 GMC 2500 4x4. P.M. our phone number and i'll let you know if he doesn't want it.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 02-14-2017, 10:50 AM   #7
There ya go. Moss Man to the rescue! I hope it works out.
Old 02-14-2017, 01:52 PM   #8
Robert555
1-ton 1973 to what year?
Thanks very much!
Old 02-14-2017, 01:56 PM   #9
Robert555
Thanks, let me know. However I'm really leaning towards the 14-bolt at this point though. I've had this truck for 30 years and it's a little light-duty for what I use it for. I've pulled the eyes off the front shocks twice. It needs a little beefing up.
Old 02-14-2017, 04:04 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Thanks very much!
I would say to the early 1990's. You want the beefier 8-lug full floating or even a semi-floating rear axle with the 14" ring gear. Bomb-proof.
The even later model version of the 14 bolt is a lighter duty 9.5" ring gear axle that was under 1/2 tons is only a 6-lug and significantly weaker than the 8-lug version.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-14-2017, 06:52 PM   #11
Robert555
Gary
My truck is a K2500 and is 8-lug, so we're only talking full floating here.
I've learned there is a major difference in drum brakes of 14-bolt rear axles. Some of them slide off the studs which is the same on my Dana 60, and some require the axles and hubs to be removed? I am only interested in the kind that allows the drum to slide off the studs (I don't want to deal with removing the axle and hubs just to check the brakes).
What year 1-ton trucks have the style of rear brake drums that just slide off the studs?
Thanks!
Old 02-15-2017, 01:08 PM   #12
GASoline71
GASoline71's Avatar
That would be the semi-floater without hubs out back. It uses regular drums like any other non floating rear end. I had one under a 1991 3/4 ton Suburban.
Gary
Old 02-15-2017, 02:21 PM   #13
Bigdav160
Bigdav160's Avatar
How bad is the spindle? They make speedi sleeves for that. Otherwise it could probably be welded and ground back down.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
