Old 02-13-2017, 08:46 PM   #1
tim71
tim71's Avatar
Another Starter Problem
I'm restoring a 71K1500. The engine,tranny and transfer case are rebuilt and back in frame. After pre-oiling the engine, I wanted to turn the motor over with the starter. The starter is new and I proceeded with sparkplugs out. When I engaged the remote starter switch, the engine began to turn over but wouldn't stop turning over until I disconnected the neg cable from the battery. The pinion gear was still engaged to the flywheel, I had to loosen the starter bolts to get it to retract. The new starter is fried, just the positive cable and ground made the starter run, solenoid dead. They replaced starter and I used 4 shims on starter 2. The pinion gear is still hanging up. At least the remote start switch is working OK, I haven't fried starter 2. How many shims can you use? Any ideas?
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 02-13-2017, 10:00 PM   #2
davepl
davepl's Avatar
Re: Another Starter Problem
Any chance your flexplate or flywheel is on backwards?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-13-2017, 11:13 PM   #3
tim71
tim71's Avatar
No, flex plate is on correctly. That's partly why I wanted to turn engine with starter. Try to see if there is any issues while everything is still easy to get to.
Old 02-14-2017, 02:33 AM   #4
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 02-14-2017, 06:11 AM   #5
Toms67
Toms67's Avatar
Could the starter you have be for a different size flywheel? Or is it an aftermarket starter? And there are more than one set of mounting holes.
Toms67 is offline   Reply With Quote
Old 02-14-2017, 07:08 AM   #6
tutone
tutone's Avatar
your problem may go away when you replace your starter. [unless it is a remote wiring issue]. Every time this has happened to me, it is the bushing on the very end of the starting motor has either broken or worn , allowing the bendix to stay engaged after shutting off the key. I have had this happen with a brand new big chain parts store starter too. I would check that first, and if that's it, it's an easy fix.
tutone is offline   Reply With Quote
