Old 02-13-2017, 09:35 PM   #1
wpavlis
evaporust is the best
I have been using this stuff for a while on small screws and hardware. I am currently removing rust from my interior heater box. I broke down and bought a gallon of it so I could get rid of the light surface rust I can't reach with a wire brush. Can you tell how high the bath went? Wow.
wpavlis is offline   Reply With Quote
Old 02-13-2017, 11:29 PM   #2
YJ_Aaron
Re: evaporust is the best
Yep, my 3.5 gallon is in route to me! Works great.
YJ_Aaron is offline   Reply With Quote
Old 02-14-2017, 12:06 AM   #3
clay68c10
clay68c10's Avatar
Thanks for the reminder, I'll be needing some soon. Lots of rusty old crap to clean up. It works amazingly well.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-14-2017, 01:35 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That looks real good. Ever try white vinegar? It turns rust black then comes off with a brush. The Evaporust may be better for heavier rust.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-14-2017, 09:06 AM   #5
RPBurris
RPBurris's Avatar
My 80 year old uncle thought i was pulling his chain about the vinegar trick. But at a fraction of the cost you get nearly the same results. He had about 100 clamps that were rusted up. A good soak in vinegar overnight and they were almost like new again. I do like the Evaporust products but cant spend the money when i know there is an alternative. Come to think of it i think i learned about the vinegar trick on this forum!
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 02-14-2017, 11:08 AM   #6
zicc1835
zicc1835's Avatar
Attachment 1622228
Besides a guy that does Cadium platting (they are getting harder to find EPA)is there an alternative to coating nuts bolts that go thru evaporust treatment or acid bath or sand blast and then there is my new hardware ....clear coat it so it doesn't rust ? Anybody better way on these issues?
zicc1835 is offline   Reply With Quote
Old 02-14-2017, 11:23 AM   #7
coreyjhen
If you don't mind the looks of galvanized metal, try this: http://bit.ly/2lGoS36.
You can also buy "blueing" solution from gun builder suppliers. The metal turns a bluish black, and is pretty rust-resistant.
coreyjhen is offline   Reply With Quote
Old 02-14-2017, 07:16 PM   #8
71CHEVYSHORTBED402
WD-40 works well also. If there's any level of rust on the parts I soak them in white vinegar overnight, like you do. Then I soak all hardware in WD-40 overnight, or when I get to it. That with a wire brush they look like new. At some point the parts will be black zinc plated.
Tony
