Old 02-13-2017, 11:21 PM   #1
Normy71
Exhaust
looking for some suggestions for a exhaust system for my build
Ls swap, headers,porter built stage 2 rear suspension system on air,rear Boyd fuel tank.
Should I use a x or H pipe and what mufflers work best, how should the tail pipes be run?
Thanks!
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 02-14-2017, 12:00 AM   #2
sprint_9
sprint_9's Avatar
Re: Exhaust
Im at about the same stage with similar components. Im interested to see what others have to say on the topic as well.
I was leaning toward some type of x or h crossover, Borla mufflers, and dumping right before the rear axle or out the side of the box. And Ive been toying with the idea of cutouts.
sprint_9 is offline   Reply With Quote
Old 02-14-2017, 09:26 AM   #3
Normy71
Re: Exhaust
Sprint 9 what size exhaust would you run, and have you researched borla mufflers or heard them on a Ls?
I'm still at frame stage on my build but I would like the tail pipes going to the very back
If it will work.
Old 02-14-2017, 09:48 AM   #4
67 chevelle
67 chevelle's Avatar
Re: Exhaust
I like H-pipes and magnaflows , borlas are nice also 2 1/2 inch pipe should be good , unless you are 450 hp plus , then you want dual 3 inch
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-14-2017, 10:04 AM   #5
coreyjhen
Re: Exhaust
Here's a good calculator: http://bit.ly/2kOH3SG. Required size is smaller than you might think - all those rice burners with their four-inch exhausts are wasting money. As for mufflers, at realistic power levels, it doesn't much matter which mufflers you choose: http://bit.ly/2lLQi4j, so use the ones you think sound best.
coreyjhen is offline   Reply With Quote
Old 02-14-2017, 10:05 AM   #6
Normy71
Re: Exhaust
I want something with a nice rumble at idle and a bit of a bark when you get on the throttle, not ear ringing loud like a glass pack.
Old 02-14-2017, 10:08 AM   #7
Normy71
Re: Exhaust
Cool calculator Cory!
Thanks for the info!
Old 02-14-2017, 10:11 AM   #8
Ekliptix
Ekliptix's Avatar
Re: Exhaust
I like spintech mufflers. They have a range of series for varying loudness. The X pipe is supposed to work better to help exhaust exit your engine vs an h-pipe. Something about alternating pulses from left to right.
Here's a sound clip of my 402 with spintech 3000s and an x pipe (3 inch). https://www.youtube.com/watch?v=An3NhSvO9-M
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 02-14-2017, 10:20 AM   #9
Normy71
Re: Exhaust
Wow nice bunch of classics!
Love the clip, nice sound love the paint choices!
This is getting good more please!!!!!
Old 02-14-2017, 04:03 PM   #10
jessemthompson
Re: Exhaust
I run spintechs as well on my 5.3. Pretty tame at idle, but comes to life at full throttle.
jessemthompson is offline   Reply With Quote
