Old 02-13-2017, 11:21 PM   #1
68 c20 cst
68 brake question
I was taking my truck apart for a long bed to short bed conversion and found this proportioning valve. Haven't seen one like this. Would this set up be good for disk drum? I have drum drum now.
68 c20 cst is offline   Reply With Quote
Old 02-13-2017, 11:52 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 68 brake question
Not sure what that is but I don't think it is a proportioning valve. A proportioning valve has to be connected to front and rear brakes and is only used with disk/drum setups..... Drum/drum brake systems use a distribution block.
LockDoc
Leon
Old 02-13-2017, 11:56 PM   #3
camtoys1
thats adjustable proportioning valve.
camtoys1 is offline   Reply With Quote
Old 02-14-2017, 12:40 AM   #4
LockDoc
LockDoc's Avatar
It isn't going to do what it is supposed to just hooked up to the front brakes.
LockDoc
Leon
Old 02-14-2017, 01:35 AM   #5
RichardJ
>>It isn't going to do what it is supposed to just hooked up to the front brakes.<<
Wrong. I am guessing and assuming it is connected to the rear brake line only, which is correct.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-14-2017, 07:13 AM   #6
68 c20 cst
Yes it's just on rear brake line. So would this setup work for disk/drum? Or would I still have to change booster/MC/PV?
Old 02-14-2017, 07:39 AM   #7
Grumpy old man
Grumpy old man's Avatar
Thats a 64-73 Ford Mustang adjustable prop valve
https://www.mustangbrakeparts.com/pr....asp?prod=9422
old school trick for trailering or cheap mans option for line lock .
Call pirate jacks for all your brake questions http://piratejack.net/
Grumpy old man is offline   Reply With Quote
Old 02-14-2017, 10:52 AM   #8
LockDoc
LockDoc's Avatar
So what is it supposed to do on a drum/drum brake system, only connected to the front or rear? (other than what Grumpy suggested)
LockDoc
Leon
Old 02-14-2017, 11:00 AM   #9
67 chevelle
67 chevelle's Avatar
Get one of these
http://www.ebay.com/itm/GM-CHEVY-DIS...FXdMFO&vxp=mtr
That way you will have a warning light , and the proper valve
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 02-14-2017, 04:23 PM   #10
RichardJ
>>So what is it supposed to do on a drum/drum brake system, <<
I'm guessing again, but I imagine the guy was having a problem with the rear brakes locking up. Assuming all the drums were working as they should, I think you are looking at a very aggressive driver with poor brake habits that frequently drive in adverse conditions.
Any truck with no load will have a lot of weight transfer, rear-to-front when braking. That truck has a heavy Big Block and big ass brake booster. You add that to someone that drives too fast in the rain, tailgates and jumps on the brakes at the last minute and that truck might be prone to swapping ends.
Below is an adjustable proportioning valve used on some trucks before ABS brakes became common place. When the bed rises, the arm connected to the axle, adjusts the proportion valve to reduce the pressure to the rear brakes. With a load in the bed, the valve doesn't reduce rear pressure. There is less rear-to-front transfer, the tires are loaded and the wheels don't lock up.
Yes, a Combination Valve would add a warning light switch and also add a Metering Valve for the front brakes.
When you add disc brakes, the truck may have a tendency to nose dive at very low speeds with light brake pressure then a Metering Valve would be very useful. In other words, if you plant your girlfriends face in the dash at red lights, either add a free standing Metering Valve or replace the adjustable prop valve with a Combination valve that has a fixed proportion valve and you should be good and ready for the disc/ drum set up.
The adjustable valve is better than a fixed valve, but probably not needed.
Old 02-14-2017, 06:14 PM   #11
LockDoc
LockDoc's Avatar
Yeah, it's hard telling what he was up to.
To the OP: When you do the disk swap I would just put the correct combo valve on it and set it up correctly, like Richard said....
LockDoc
Leon
Old 02-14-2017, 06:24 PM   #12
68 c20 cst
Thanks to everyone for your help
