Old 02-14-2017, 09:29 AM   #1
nastety92
Adding Power Steering
What is the easiest way that we can add power steering to the 67 GMC Suburban 2wd? Right now it is manual steering and we are in the process of installing a used 5.3 V8 out of an 04 Suburban. While we are in there we thought it would be a good idea to add power steering.
Thanks for the help,
Nick
nastety92 is offline   Reply With Quote
Old 02-15-2017, 11:23 AM   #2
nastety92
Re: Adding Power Steering
I've searched for this power steering info. It looks like I have to just buy a new power steering box from a 77-80 C10. Just wondering if anyone has done this mod when adding a LS or 5.3L.
Thanks,
Nick
Old 02-15-2017, 02:48 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Thanks,
Nick
I did and I used the LS power steering pump and adapted it to the steering box. Mine was a '76 box so it didn't have the metric fittings on it.
You might get some info from this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=652626
LockDoc
Leon
Old 02-15-2017, 02:50 PM   #4
nastety92
Thank you sir. What would this forum do without you.
I'll start the search for a 78 Steering box.
Nick
Old 02-15-2017, 02:53 PM   #5
LockDoc
LockDoc's Avatar
Nick
...There was a lot of information on here before I ever joined. If you have any more questions post them up and we will try and answer them for you....
LockDoc
Leon
Old 02-15-2017, 02:53 PM   #6
nastety92
Will do Leon. I do try and search but sometimes it bring up TOO many posts to look through everything. I do appreciate the help.
Nick
Old 02-15-2017, 03:57 PM   #7
Bigdav160
Bigdav160's Avatar
The PS truck boxes are similar from '68 until '87 or '91 for Blazer/Suburban.
You '67 from probably doesn't have the dimple in the frame to clear the box and most people use a spacer. This causes your pitman/idler arms not to be parallel with the frame members but unlikely to be a serious issue.
I do not know if your current steering linkage can be used. Many gain power steering and disc brakes when they convert the whole thing over from a later model truck.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-15-2017, 03:59 PM   #8
nastety92
Could the frame be modified to accept the box? As in have someone put a dimple in the frame or is that not an option?
Old 02-15-2017, 04:57 PM   #9
Bigdav160
Bigdav160's Avatar
'67 Flat frame:
'67 with power steering adapter plate:
'68 and newer frame horn:
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-15-2017, 05:01 PM   #10
Bigdav160
Bigdav160's Avatar
Off Road Designs sells a frame repair kit for cracking around power steering box.
Perhaps it can be used to modify a non power steering frame?
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-21-2017, 04:49 PM   #11
nastety92
Thanks for the pictures Bigdave. That really clears up what needs to be done.
Old 02-21-2017, 05:44 PM   #12
Average Joe
Average Joe's Avatar
There is a slim chance your frame may already have the dimple. My '67 did. You might want to confirm on yours before ordering parts.
Your existing steering linkage should work with the newer box. I originally converted mine with a box off an '86 3/4 ton with that pittman arm and it bolted right up. I did have the metric threads for the hoses to deal with, but I just swapped the bung in my P/S pump from the '86 and used the newer hoses. TX Firefighter did a thread on this IIRC.
Just my experiences. Hope it helps.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-22-2017, 12:10 AM   #13
HO455
Post Whore
HO455's Avatar
Here is a current thread on the pickup side with some information that may help you.
http://67-72chevytrucks.com/vboard/s...=1#post7866091
RIP Bob Parks.
Old 02-22-2017, 08:45 AM   #14
nastety92
Thanks for the help. That is a good thread for reference. I'm looking forward to see if that new box works for him.
Nick
