Old 02-14-2017, 05:13 PM   #1
miller6t9
miller6t9's Avatar
vintage air SBC to LS ??
anybody already have a Vintage air system installed on a small block and then decided to go LS? I'm kicking the idea around about an ls1/6 and dont know what will be involved with the engine swap concerning the Vintage air I've already got.
miller6t9 is offline   Reply With Quote
Old 02-14-2017, 05:24 PM   #2
cooperhw
cooperhw's Avatar
Re: vintage air SBC to LS ??
Shouldn't be a problem unless you try and run a "stock variable speed compressor". Call Vintage air. They have really knowledgeable guys who love to talk AC systems. Really helpful I have found.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 02-14-2017, 05:32 PM   #3
weq92f
weq92f's Avatar
The challenges as I see them:
Nothing in the cab should need to change
bracketing and mounting of accessories
-- compressor, may or may not mount to an LS
-- if it can be mounted, no issue, otherwise maybe new compressor
routing of lines/hoses
-- if you keep everything in the same location under the hood, no issue
-- if compressor swaps sides, routing of the lines/hoses would be issue
-- if condenser,dryer has to be moved, same thing
-- for the heater, I figure some new hose would do it.
Clearance
-- the LS may or may not allow your current equipment to stay as-is
Otherwise, the VA system doesn't really care what motor you're running. That is, unless you also purchased the Front Runner system!
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
