Old 02-15-2017, 04:07 AM   #1
Cadillac Kid
Cadillac Kid's Avatar
Folding Bench Latch Location?
Hello everyone.
I don't think my truck is equipped with the folding front bench, but I just want to be sure. I see the lever for the back and forth seat adjustment, but I do not know where the folding lever would be. Could someone let me know or maybe post a picture?
Thank you very much, this forum is wonderful.
-Gavin
Cadillac Kid is offline   Reply With Quote
Old 02-15-2017, 05:13 AM   #2
donut
donut's Avatar
Re: Folding Bench Latch Location?
Check where the seat back and bottom portion of the seat meet. Hinge point if you have one. (right above the seatbelt retractor)
My '73 did not have one.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-15-2017, 11:43 AM   #3
TKCR
TKCR's Avatar
It would help knowing what year of truck you have.
Some seats had tilt, some didn't. Most of the 80's just fold forward, they don't have a latch or lever. They just fold forward by you folding it forward.
Old 02-15-2017, 06:31 PM   #4
f.monroe
f.monroe's Avatar
Looking at your other postings I see you have a '74. It probably doesn't have a tilting seat. Not all did back then. If you can't get it to tilt ,and can't find a lever at the rear base of the seat, it's probably a fixed seat.
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-15-2017, 09:45 PM   #5
Gmc.guy
Gmc.guy's Avatar
Both of my '74 s do not have the folding seat. The cover for the seat back wraps the "arm" that bolts to the seat bottom. Super pain for storage when you are used to using it on another truck
-Cody
Gmc.guy is offline   Reply With Quote
Old 02-17-2017, 01:47 AM   #6
El Dorado Jim
Size:  35.3 KB you can modify your seat to fold forward by using a piece of angle iron like I did...this is in my 72, but will work on newer seats as well
El Dorado Jim is offline   Reply With Quote
Old 02-17-2017, 06:35 PM   #7
Gmc.guy
Gmc.guy's Avatar
^^ are the bolts shouldered so they can stay tight but let the back pivot ? I was just curious if they stay tight or you have to tighten them once in awhile
-Cody
Old 02-17-2017, 07:04 PM   #8
TKCR
TKCR's Avatar
[QUOTE=Gmc.guy;7861903]^^ are the bolts shouldered so they can stay tight but let the back pivot ? I was just curious if they stay tight or you have to tighten them once in awhile[/QUOTE
Yeh it needs to be shouldered. Here's the bolt that goes in the tilt seats
Old 02-17-2017, 07:10 PM   #9
midnight rambler
midnight rambler's Avatar
whats the thread and bolt size are those or if you have a part number ? I like this mod makes it simple
midnight rambler is offline   Reply With Quote
Old 02-17-2017, 10:39 PM   #10
Gmc.guy
Gmc.guy's Avatar
Yes, I have taken the tilt ones apart before. I was just wondering if using the original in a non tilt seat was shouldered and could be used. Never took the non tilt apart before. I assume it doesn't have a shouldered bolt
-Cody
Old 02-18-2017, 02:45 AM   #11
TKCR
TKCR's Avatar
The non tilt doesn't use shouldered bolts, it just has 2 bolts that mount the seat back to the seat bottom frame. That is why it doesn't tilt. Now if you took the top bolt out and put a shouldered bolt in the bottom hole, and then put a bolt or a stop of some sort in the hole next to the orginal hole, then it would tilt. The seat bottom frame has two weld nuts, side by side. I'll have to get pics of what I mean, because I just took apart a non tilt seat last weekend. I saw how it's put together vs. the tilt seat.
Pictures explain a whole lot better than words do.
Old 02-18-2017, 03:30 AM   #12
Gmc.guy
Gmc.guy's Avatar
Cool I appreciate it. I can picture what you mean. That's my problem, I explain things in a rough way haha
-Cody
Old 02-18-2017, 11:10 AM   #13
TKCR
TKCR's Avatar
So the frame on the first pic, this hole is used for the stop on the tilt seat. The hole down lower on the frame, is for the shouldered bolt. This is what allow the seat to tilt.
The other pic of the seat bottom frame, the inside hole, is what is used for the non tilt seat. A bolt would mount the seat back in 2 places, which of course, would keep the seat from tilting. There are 2 holes in the seat back, it's hard to see because of the sun. So you would remove both bolts and replace the bottom bolt with a shoulder bolt. And then place a stop, which is just a bolt, using the hole in the frame (1st pic). Now the seat back will tilt. It will look just like what El Dorado Jim posted #6
Old 02-20-2017, 02:04 AM   #14
El Dorado Jim
just re-use the tapered screws that are on the seat already,you don't need any other bolts, look at the pics I posted, use a piece of angle iron, drill a hole in it and countersink the hole, mine never loosen up.if they were to I would just use a little bit of blue loctite....I can post a close up if you guys need a better pic..
