L31 timing cover hole
I have an L31 crate engine and need to plug the crank sensor hole in the timing cover. Can I use a freezeplug? I would prefer to not have to replace the timing cover.
Posted via Mobile Device |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: L31 timing cover hole
If you can find a freeze plug the correct size and install it without breaking the cover, that should work. I was thinking that GM makes a plug for that?
http://67-72chevytrucks.com/vboard/s...d.php?t=396643
