02-16-2017, 12:42 AM | #1 |
How did I get this OLD!
Chevelle/Camaro sport steering wheel
Anybody put the comfort grip steering wheel on our trucks?
If so which hub did you use 67-68 style Chevelle or 69-72 style? I got a nice blue rim Chevelle wheel at a swap and thought the 15" would be nice with my power steering. Just need the button,hub and horn components.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
02-16-2017, 09:27 AM | #2 |
Re: Chevelle/Camaro sport steering wheel
I've used that wheel in plenty of these trucks, but couldn't say which hub I used on each one. I guess I just got lucky and they fit.
02-16-2017, 12:55 PM | #3 |
Old member
This is the hub I have always used. Factory correct. Will fit our trucks.
I haven't found one that didn't work. They maybe out there but I've not seen one that didn't. This one. http://www.classicindustries.com/pro...s/3937896.html Same adapter just higher price. $100.00 http://www.mamotorworks.com/corvette...steering-wheel E bay same thing just over priced. $80.00
02-16-2017, 03:49 PM | #4 |
IIRC, the 67-69's use a 4 1/8 diameter column and the 70-72's use a 41/4 diameter column.
So match the hub to your column year/size. I got the hub with mine when I bought if off of ebay.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-16-2017, 05:29 PM | #5 |
I did
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
02-16-2017, 05:51 PM | #6 | |
You use the hub for the original application that applies to the truck column. That being said, the truck column is the same diameter as a car column that does not have the key on the column, therefore the proper hub is the 67-8 one. Cars 69 and later got the key on the column. Either will fit as the splines are the same and the mounting depth is similar. The later hub just doesn't match the diameter of the column very well, the earlier hub looks much much better. If this thread lives I will post a picture of each mounted since I have one of each. |
02-16-2017, 06:51 PM | #7 |
Old member
I have a 67 SS Chevelle wheel in my 71 C-10 I have the older corvette wheel mounted on the Ramp Rat. The Chevelle is not got the hub it's part of the steering wheel like the factory truck steering wheel.
The corvette has the hub. I'm going to install the tilt column with the wood grain wheel soon I hope. I have to sand it and have it dipped and then install it.
02-17-2017, 09:09 AM | #8 |
For the ignition switch on the dash GM vehicles, use the 67-68 wheel. For ignition switch on column, use the 69+ wheel.
02-17-2017, 09:46 AM | #9 |
Blue/72, what's that wheel from? I really like that one.
02-16-2017, 05:32 PM | #10 |
While we are on the subject, how do you install the horn button? I cannot get mine centered.
02-19-2017, 07:16 PM | #11 |
Ben, thanks for the tip on the horn button. I will try that.
02-19-2017, 09:06 PM | #12 |
Blue/72's wheel appears to be the Camaro Comfort Grip wheel. I have the same one in my short step as well as my Camaro and my '79 CJ-5 because why not?
02-20-2017, 12:34 AM | #13 |
