Old 02-16-2017, 03:19 AM   #1
67seaten
67seaten's Avatar
rear end gear ration for t56
hey guys , wondering what the best gear ratio that i should be using , running a ls1 with a t56, thinking about running a 27 tall tire
mike
67seaten is offline   Reply With Quote
Old 02-16-2017, 05:29 AM   #2
rob32472
Re: rear end gear ration for t56
What motor/cam combo are you planning to go with?
rob32472 is offline   Reply With Quote
Old 02-16-2017, 01:41 PM   #3
trkfrk
trkfrk's Avatar
Use this gear ratio calculator. http://www.grimmjeeper.com/gears.html . It really helped me and takes the guessing out of the equation. You can play around with it. I went from 3:73 to 4:56's. I tach 2,000 RPM/80MPH/6th gear and average 17MPG.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 02-16-2017, 01:56 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
With OD you don't really want anything higher (numerically lower) than a 3.73 in these heavy old aerodynamic bricks. My truck is happy with a 700R and 3.73 and turns around 2300 RPM at 75 mph. I believe the T56 has an even greater OD ratio (like 0.63?) vs the 0.7 of the 700 will lower the rpms even more. A 4:11 would probably be a good match as well if you want more low end grunt and still be good on the highway with the 0.63 OD.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-16-2017, 03:06 PM   #5
67seaten
67seaten's Avatar
running a ls1 with a mild cam , gonna be alot of street driving some highway driving , i have a set 456's on the shelf for another project . if they do work well with this set up i will use them ,i didn't want to put it in they didn't work then end up taking it out
mike
Old 02-16-2017, 03:29 PM   #6
sangell
What is your t56 out of? They had different ratios, the most common behind the LS motors are the F-body version with a .50 6th. In my son's truck we have a CTSV T56 with the .56 6th gear and 27" tires. I put a 4.56 in it. With the low rear gear and high OD ratios you need to watch out for drive shaft RPM. His truck was a long bed and I tried to run a one piece shaft that didn't work out. With 27" tires, .56 6th gear it was 2400 rpm at 75mph which put the drive shaft at 4300 rpm and it was not happy. The drive shaft is a 4"x.083 wall steel piece. We have since cut the truck down to a shortbed so that makes the driveshaft 12" shorter and I'm dropping to either 4.10s or 3.73s. I think the 4.10s are the way to go but the 3.73s help so much with the drive shaft RPM.
sangell is offline   Reply With Quote
Old 02-16-2017, 03:37 PM   #7
sangell
So are you running roughly a 30" tall tire?
Old 02-16-2017, 05:17 PM   #8
trkfrk
trkfrk's Avatar
Yes, 295/45/20 which equals 30.45" OD.
Mark
Old 02-16-2017, 05:42 PM   #9
Heavymetl
Driveshaft speed is the killer here. I'd say 4.10s would work, but look into aluminum for the driveshaft material.
I run 4.30s in my T56 Camaro, but it's got a relatively short 3.5" diameter aluminum driveshaft and runs smooth as butter at any speed.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 02-16-2017, 06:58 PM   #10
sangell
When you get to big dia thin wall steel they have a equal or higher critical speed than an AL shaft does.
Old 02-17-2017, 09:08 AM   #11
Mike C
Mike C's Avatar
Some good advice above. My recommendation for the .5 OD T56 would be 4.56 at a minimum. Especially if you are running a carburetor still. FI allows for even lower cruise speeds and good AF ratio.
I wouldn't consider 4.88 to be out of line with a 30/31" tire either.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-17-2017, 09:50 AM   #12
sangell
This is from Mark Williams
Old 02-17-2017, 06:52 PM   #13
67seaten
67seaten's Avatar
thanks guys , its out of a camaro i am gonna stay efi , 27-29ish tall tire is what i am planning on running , aluminum drive shaft will be the way ill go , i will need a custom made once everything is together
mike
