Radiator Conundrum
I recently bought a 350 with a 700R4 to replace the 230 and three-speed in my '63 C10. I am now looking into radiator options. Is there any reason I couldn't or shouldn't use a flange mount style radiator as used in the '60-'62 year models? It just looks like such a simple option as opposed to rounding up all the necessary hardware for the '63 up style mounting system.
I am considering a Champion aluminum radiator similar to the one in this picture. |
Never Ending Projects
Re: Radiator Conundrum
There is no real reason, if you're not looking for a somewhat original setup. I have seen all types of mounting solutions over the years. I think my buddy just when with this type of flange mount setup because he didn't have all the original mounts. Working great for him.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Jan 2011
There was a thread not long ago on this type of setup. He made the brackets and welded them to the radiator support. Then he had no place for his battery box to mount. Just something to look at.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Champion has models to fit the 63 like a glove. Do you have the stock radiator in there now or? The stock will cool the 350 just fine if it's in good shape and maintained well. I have a champion and it cools my LS great, I went that way due to leaking original rad.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I'd also recommend a fan with a shroud...I had that set up in my 61 and it overheated in the 100 Degree Central California heat. With the shroud and fan combo, no more problems even in bumper to bumper traffic and the ac running.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
Agreed! I have 2 12" fans, one for ac/high pressure and one regular, both in an aluminum shroud.
I heard that the radiator is good but the fan is cheep.
Thank you everyone for all your input. I have a Champion three row radiator in my '61 Biscayne cooling a 350 with a/c. I used a stock V8 shroud and it does well, even on the hottest of days. I mostly just needed to confirm the earlier 60-62 flange style mounted radiators will fit a '63.
I like the idea of the flange style as well eliminating the top and bottom bracket clamp style. It pulls the radiator a bit more forward as well filling in the gap. May have to consider this myself with the LS3 conversion I did.
#10 | |
Wolfman, i'm interested in this statement as i just put a Champion 3-row into my '61. Do you have experience/proof with the 2-row cooling better or just the theory of two bigger tubes vs three smaller tubes?
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
#12 | |
#13 | |
#14 | |
#15 | |
#16 | |
2 row with .75" tubes 3 row with .63" tubes Also their American Eagle that has 2 rows of 1" tubes. |
#17 |
I have the last one, cools my LS nicely. I had the 2nd one but it developed a small leak at the neck and was replaced under their lifetime warranty.
The 3 row will cool to 600hp, the American eagle 1" core will cool 750HP is what I was told.
#18 |
Trust me i have a mostly stock engine no cam just exhaust intake carb and HEI .. and it did not cool mine till i put in the 2 row with 1 inch tubes ... funny thing is when I called up to order it they told me that the three row would cool mine too and then when I started having problems and called them he said oh well you should have ordered a 2 row lol so yeah they were kind of a little abrasive to deal with in that manner because I have to admit I was rather frustrated with them telling me the first time the wrong radiator been having me go through this mess but I have to say other than that being that they sent me out a new radiator right away with no money charge to me and went by the promise that I would send back the three row their customer service was good not many companies would do that
#19 |
I have the American eagle(Champion's other brand) two core with a single fan. It was getting pretty warm on me. I have no shroud though. I have a dual fan set up to put in soon. The radiator seems pretty well built
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
#20 |
If it is the fans that they make or send with the radiator don't bother they are junk the Shroud that comes with the radiator if you ordered it that way is good sometimes depending on the application it takes a little modification for the Shroud to work even better but the fans themselves are garbage do yourself a favor if they are those fans buy different ones
#21 | |
#22 | |
I pulled the trigger and ordered the Champion American Eagle radiator from Jeg's yesterday. It has two rows of 1" tubing as you had recommended. I went with the 60-62 flange mount style to save the trouble of rounding up all the necessary pieces for the 63-66 mount style. I also ordered a full cover aluminum shroud and a 16" Flex-a-lite Syclone electric fan. I hope this combination does the trick for my little 350. Thank you to everyone for the valuable tips. Danny |
#23 | |
#24 | |
#25 |
Who Me?
I went with a Champion in my 61 with 1 16" fan and it worked perfect.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
