Old 02-16-2017, 08:33 PM   #1
davepl
davepl's Avatar
Could you blow yourself up this way?
[Please move this to electrical if it's too specific, but it's kind of a general safety question, so putting here for now]
It used to worry me that the fuel tank sender operated on 12V, but then I eventually figured out that there's a ton of resistance in the circuit, so there's pretty much no way it could ever arc or spark inside the fuel tank.
But as I was about to start troubleshooting a gauge issue with my power probe, I had to wonder:
What if I used it to inject a FULL 12V into the sender wire? Couldn't that spark/arc internally at the fuel tank sender?
If it were submerged, you'd still likely be OK, but if the fuel level was low enough that the sender mechanism was above the fuel line, it'd be sitting there in vapor, and... boom?
I'll definitely put it on my "don't try it" list, but I'm surprised I've never heard of anyone accidentally hooked it up wrong or otherwise sending a full non-resistance 12V into it by mistake.
Or maybe it happens all the time and it's still safe for some reason I haven't thought of?
Dave
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-16-2017, 08:39 PM   #2
dave`12
dave`12's Avatar
Re: Could you blow yourself up this way?
There is a reason that the wire going to the sender completes the ground, rather than being positive
dave`12 is offline   Reply With Quote
Old 02-16-2017, 09:03 PM   #3
Gmc.guy
Gmc.guy's Avatar
I think it would have to depend on the upper and lower explosive limit. Upper would be a concentration of vapours too high to ignite (rich) and lower not enough (too lean) . It takes a sweet spot to blow stuff up. We deal with it in natural gas but I'm not sure of the % or ppm for gasoline
-Cody
Gmc.guy is offline   Reply With Quote
Old 02-16-2017, 09:16 PM   #4
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Another mystery we will never solve. When someone finds the answer they probably won't be able to share it with us.
CaptRMW is offline   Reply With Quote
Old 02-16-2017, 09:23 PM   #5
Gmc.guy
Gmc.guy's Avatar
(Faint boom in the distance) and a pile of birds fly by
-Cody
Old 02-16-2017, 09:31 PM   #6
davepl
davepl's Avatar
Can you explain? It completes ground so that current can flow from a very restricted source at the gauge to the ground drain in the sensor, right? There's only one wire.
What I'm talking about is when you replace that highly resisted source with a straight-to-battery source, with no resistance. The ground circuit is completed through the send, and a full "whatever the circuit can carry" current path is established.
The resistance could be in the actual sending unit, but it's only 90 ohms, not a ton of resistance so far as I'm aware.
I'm a software guy, not a hardware guy, so type slowly so I can follow!
Old 02-16-2017, 09:38 PM   #7
72_K10_Vegas
72_K10_Vegas's Avatar
Google "Intrinsically Safe" and fuel.
72 K10
72_K10_Vegas is offline   Reply With Quote
Old 02-16-2017, 09:56 PM   #8
davepl
davepl's Avatar
Ok, now explain why you believe this circuit to be intrinsically safe if 12V is injected into the sender wire...
Old 02-16-2017, 10:21 PM   #9
71BUCKET
One of my other cars had 3 450gph pumps sittings in fuel with a lot of voltage going to them. Running both 93 octane and e85, no issues
71BUCKET is offline   Reply With Quote
Old 02-16-2017, 10:30 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
I have a walbro 255 fuel pump in my tank. No problems so far...
brad_man_72 is offline   Reply With Quote
Old 02-16-2017, 11:36 PM   #11
franken
The ground side or positive side has nothing to do with anything. The same current flows through a circuit and the same energy is used regardless. Current flows to and from a source. Nothing is lost. Its sort of like if you walk out your front door, turn left or right and eventually walk back in. Same number of steps.
Lots of people who know nothing about electricity will give you lots of BS info. Learn Ohm's Law.
franken is offline   Reply With Quote
Old 02-17-2017, 06:02 AM   #12
rob32472
Liquid fuel is difficult to ignite as long as everything stays submerged there is no chance it would ignite and explode. If you have any fuel in the tank, the vapor concentration is far past what you can ignite. (gasoline doesn't burn at all. gasoline vapors burn, and it has to be between 1 and 7% vapor to air. Any more or less and it won't do a thing) The only time you would get that low of a concentration of vapor in the tank is if it is absolutely empty, in which case you aren't moving the sender anyway.
rob32472 is offline   Reply With Quote
Old 02-17-2017, 09:04 AM   #13
palallin
Dave
It depends upon which network news show is recording the story. "Film at 11."
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 02-17-2017, 10:50 AM   #14
James the III
Cus, most don't probe a ground wire with 12v+
if they need to check that wire it's for electrical continuity , it's with micro amps of power.. that not ark.. looking for a break..
James the III is offline   Reply With Quote
Old 02-17-2017, 11:16 AM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Dave
Do not ever apply a full 12 volts to the sending unit wire. At the very least you will damage the variable resistor on the sender, and at worst it may ignite the fuel vapors in the gas tank and cause an explosion and fire, and burn down the truck and possibly cause injury or death.
The fuel gauge receives a full 12 volts from the ignition switch via the fuse panel, and this voltage runs through a resistor on the back of the gauge. This voltage also powers the needle coils in the fuel gauge. This combination of resistances causes a voltage drop from the original 12 volts to about 8 volts, and then the current pushed by this lower voltage is routed back to ground through the tank sender, variable resistor.
The lower voltage is not enough to push enough current through the variable resistor to damage it, or cause an overheat or spark problem.
Now suppose you increase the voltage to a full, non- resistance, 12 volts. It would consist of a short to ground through the variable resistor, which would probably cause it to overheat or glow, and possible burn in two and even create a spark when the wires parted.
The chances of this happening are greatest when the fuel level in the tank is low or empty and the VR is exposed. This is when the resistance is lowest in the sender VR. It 's range is 0 to 90 ohms 0 being empty and 90 being full.
As an example, if you take a tail light bulb and put 8 volts on it, it will be very dim or barely glow, and then increase the voltage to 12, and it will burn your hand if you hold it. That's because at 8 volts, there is not enough current going through the filament to cause it to heat enough to glow, due to the lower voltage ( electromotive force) being insufficient to force the current through the resistance. So we add more voltage and the current flow increases and the bulb glows and gives off more light. It also gives off more heat.
All these situations are due to the relationship between voltage, current and resistance. Ohms law.
Another way of looking at it would be to picture a furnace igniter, or gas dryer, or stove, and even a glow plug in a diesel engine. If the variable resistor were to glow hot enough, it could ignite the fuel vapors in the tank. I believe 7 to 1 is the ideal air/fuel mixture for internal engine combustion, however I also believe it could take place at a lower or higher ratio.
The fuel pumps in the modern tanks are spark enclosed and isolated from the fuel so there is no worry of sparks or explosions with them.
Here is a website that is very good for checking fuel gauges and it has a diagram illustrating how the fuel gauge and sender are wired.
http://6066gmcguy.com/Electrical-02.html
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-17-2017, 11:35 AM   #16
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You go first...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-17-2017, 01:23 PM   #17
davepl
davepl's Avatar
Maybe Ohm's Law is printed on the back of my engineering degree. Not sure, I'll have to check. Until then, I'm learning so much!
I think this thread proves that a little knowledge is a dangerous thing.
Old 02-17-2017, 01:25 PM   #18
davepl
davepl's Avatar
Thanks! I'll take that as a "Yes" to my original post and confirmation that the scenario I'm describing (12V injected to sender wire) is a "bad" thing to do. You described it exactly as I envisioned it, complete with low fuel levels being the most dangerous time to make the mistake.
But I thought it was "intrinsically safe"
Old 02-17-2017, 04:43 PM   #19
Wrenchbender Ret
I've often wondered about that. The hot wire to the dome light & the wire to the sending unit all run down the edge of the floor. I've pulled the threashhold plate up & found them all corroded & bare. It seems that if those two shorted with each other it could get exciting.
Wrenchbender Ret is offline   Reply With Quote
Old 02-17-2017, 04:53 PM   #20
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
There's 3 components required to support combustion - 1) fuel 2) oxygen 3) heat. There's not ample oxygen in the fuel tank, only gasoline vapor.
suprachrgd82 is offline   Reply With Quote
Old 02-17-2017, 05:10 PM   #21
luckylogger09
I understand a gallon of gas equals 22 sticks of dynamite. So it won't matter.
luckylogger09 is offline   Reply With Quote
Old 02-17-2017, 08:44 PM   #22
garyd1961
Just on a side note be careful probing wires on a car with airbags. A guy at work was probing seatbelt wires and set off all the airbags in the car, about six of them. Didn't hurt him but he was stunned for a few minutes.
garyd1961 is offline   Reply With Quote
Old 02-17-2017, 09:31 PM   #23
MagmaJct
MagmaJct's Avatar
Yes, and No. You are correct, the same amount of current flows through the circuit whether the resistor is on the ground side, or the positive side of the circuit.
However, having the variable resistor (inside the gas tank) on the ground side means there is pretty much zero voltage potential at the tank. If the wire shorts at or near the tank, there will be pretty much no arc (due to the resistance at the gauge).
My `74 VW handles this very differently than our trucks. The gauge has two wires to it, one positive, and one negative. However, the positive side passes through an electrical vibrator (crude voltage or current regulator) that drops the voltage or current low enough to be safe.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 02-18-2017, 10:35 PM   #24
Willie Makeit
Willie Makeit's Avatar
if you took ANY engineering classes then you were exposed to Ohm's Law.
retention of said exposure is a different topic all together.
Willie Makeit is offline   Reply With Quote
