4x4 conversion
Good evening, I am new to the forum and love all the info I’ve found here! I’m just starting a frame off restoration on my grandfather’s 1969 Suburban c10. I currently have the body off the frame and before I start the chassis restoration I want to explore the idea of a 4x4 conversion. I’ve spent every night this week sifting through the plethora of knowledge on the forum and from what I understand the easiest way to add 4 wheel drive is to find a 67-72 factory 4x4 suburban or k10/20 pickup and swap the frame (some fab required on the p/u frame). The problem is I’m having trouble finding a donor vehicle.
Will the frame of a 74 K20 mount under the burb with limited fabrication? If not are there any other models that will? I really appreciate any advice! |
The Older Generation
Re: 4x4 conversion
I have never looked into swapping a later frame but from what bits and pieces I have seen posted it includes some major fab work. Here is a thread on the subject.... http://67-72chevytrucks.com/vboard/s...d.php?t=263140 and pictures in post #13 in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=239942 As far as the '67-'72 pickup and suburban I know the body mounts are different and the suburban frame is longer in the rear and steps down. Hopefully others will chime in with suggestions. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-16-2017 at 10:02 PM. |
Re: 4x4 conversion
I have a buddy with a rolling get 72 burbank frame
Re: 4x4 conversion
Re: 4x4 conversion
It's in South Carolina....has the transmission and 205 case....I think he said 1500
Re: 4x4 conversion
Re: 4x4 conversion
Is your Suburban leaf springs or coils in the back? I would think full frame would be the way to go to replace the coil/trailing arm setup.
If leaf spring equipped adding the transfer case and front axle wouldn't be too hard and square body truck parts could probably be easily adapted.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
