Body mount and alignment question
In the process of restoring a 1970 c10
I installed new cab mounts today. Old ones were pretty shot. Question is: The front mounts came with shim plates, none for the back. I have some door, fender and hood alignment issues im working on. What area of alignment should I be checking to see if the shims are needed on the front mounts ? Also are shims ever used on the rear mounts Thanks |
![]() Join Date: Jul 2016
Re: Body mount and alignment question
Now that you mention it, never seen the rear shimmed just the front. The square ones are the shims on the front and I think I have only seen one thickness on those too
There's a good thread on this issue right now. It's about door fit issues. Just scroll down the page, or maybe the second page, and it will show up.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
Are you using stock rubber mounts or poly? I made the mistake of buying the poly ones, they sit much shorter than the originals, and once I installed my bed on the chassis, it was very evident the body lines would not align. I ended up making nylon spacers to place in between the poly mounts and the chassis to make up the difference. So, in hindsight, I should have went with the stock type, not to mention the poly ones squeak like crazy. The bed mounts only require those 2"x 2"x 1/4"square rubber gaskets also.
Just my .02 Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” Last edited by snipescastle2; 02-19-2017 at 05:30 PM. |
Are you using stock rubber mounts or poly? I made the mistake of buying the poly ones, they sit much shorter than the originals, and once I installed my bed on the chassis, it was very evident the body lines would not align. I needed up making nylon spacers to place in between the poly mounts and the chassis to make up the difference. So, in hindsight, I should have went with the stock type, not to mention the poly ones squeak like crazy. The bed mounts only require those 2"x 2"x 1/4"square rubber gaskets also.
Just my .02 Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
#6 | |
Yeah that grease may help with squeaks but still need spacers. Good move staying with the stock type.
Ben ![]()
