Old 02-17-2017, 03:02 PM   #1
Khyron
My 67 C20 Build thread.
O.k.... I hope that I have the right forum, If not, please move :-)
Sell, my story will start as a recovering Mopar guy, I got an itch to do a GM Pick-um-up truck and went on the hunt, A friend found this about 70 miles away.
She's only been on the road from the original owner, after the Original passed, the truck changed hands twice before i found it, sat both times, so i'm working with a fairly virgin piece.
I was told she was a 327, 4 speed truck.
Khyron is offline   Reply With Quote
Old 02-17-2017, 03:08 PM   #2
Khyron
Re: My 67 C20 Build thread.
spend the other day taking the front end apart, Picked up a few of 74 spindles with disks on it, will put disk on the front, after pulling her apart i checked the engine, ran the numbers and found it's not a 327, but a late model 350 4 bolt. It spind sfree, will inspect and do a minor rebuild on it. Also found a busted sway bar and sway bar mount, looks like someone pulled the ol girl pretty hard... Floors are nice, she has the normal work needed
cab corners
inner and outer rockers
front cab mount
and one section of floor.
Frame is extremely solid...
The plan, new brake system, new brake lines, lines, drop her lower, make her run and drive, enjoy the hell out of her. and keep the 8 lugs, cause that just looks cool!
Old 02-17-2017, 06:05 PM   #3
Greg58
Greg58's Avatar
Good solid foundation, keep pics coming.
Greg
Greg58 is offline   Reply With Quote
Old 02-18-2017, 01:40 PM   #4
webberjames95
subscribed
webberjames95 is offline   Reply With Quote
Old 02-18-2017, 10:58 PM   #5
ratty69
Originally Posted by webberjames95 View Post
subscribed
Me too. Cool to see you're keeping it 8 lug.
ratty69 is offline   Reply With Quote
Old 02-20-2017, 08:20 PM   #6
Khyron
Todays work. Cleaned and undercoated in the fenders. Bed removal. Frame cleaning and bed rails repair.old cab corner "repair" removed and inner and outer rockers dry fit.
Old 02-20-2017, 08:24 PM   #7
Khyron
off to summit to order some more odds and ends lol
Old 02-20-2017, 08:26 PM   #8
Khyron
I didn't know these beds unbolt into 4 pieces, as old as she is, i was able to disassemble the entire bed and only had 3 busted bolts lol
Old 02-20-2017, 09:26 PM   #9
332rick
332rick's Avatar
Nice looking truck project But it looks more like a 68 than 67?
332rick is offline   Reply With Quote
Old 02-21-2017, 07:49 AM   #10
Ken B
Very nice! I'll be following along...
Ken B is offline   Reply With Quote
Old 02-21-2017, 08:23 AM   #11
Khyron
Small rear window 67 c20 :-)
Old 02-21-2017, 01:35 PM   #12
collin70k/20
collin70k/20's Avatar
Keep the pics coming! And nice truck
1970 Chevy K20 pulling truck 406 small block
1967 Chevy K20 daily/street truck
My daily 1970 k20 - http://67-72chevytrucks.com/vboard/s...=1#post7568564
collin70k/20 is offline   Reply With Quote
Old 02-21-2017, 09:34 PM   #13
Khyron
should be a day or so for the new parts to come in, will get back on her this weekend :-), or maybe in a few days.
Old 02-27-2017, 08:35 PM   #14
Khyron
Some floor rot removed. 1 cab corner done. Door adjusted and lock fixed. after sitting in a year for 8 years the lock mechanism was jammed and stuck, removed it, parts cleaner soak and wire brush freed it up, grease and cleaned so its no longer an issue :-) Im far from a welder or a body guy, but i do the best I can, bottom rocker was mocked up in these pictures.
Old 02-27-2017, 08:38 PM   #15
Khyron
Rear cab mount. Front cab mount. Inner cab corner and inner and outer rockers done. Just got to burn it all in and i get to start on the drivers side.
I made the inner cab corner piece, happy with the way it turned out.
Old 02-27-2017, 11:04 PM   #16
Khyron
ohhhh and BUILD SHEET :-)
Old 02-27-2017, 11:47 PM   #17
Getter-Done
Getter-Done's Avatar
Wow you just made me want to look under my seat.
Wanting to add I am subscribed. You are doing an awesome job.
Old 02-28-2017, 07:47 AM   #18
Ken B
Coming along real nice!
Old 02-28-2017, 11:22 PM   #19
Khyron
Thanks for the compliments :-)
Today I Removed drivers side floor... Removed front cab support. Replaced cab support and floor. Cut out read cab support and read cab corner. Started mock up on that...I will have my kids tomorrow so this is it for a few days, I will try to get some more work Thursday :-) I need to get this body done So I can get her to make some noise LOL
Old 02-28-2017, 11:24 PM   #20
Khyron
she looked so much more solid sitting in the field for 8 years LOL
Cant wait till I can hide my ugly welds with seam sealer LOL
