10-16-2003, 10:18 AM | #1 |
Dad's little helper
trailing arm ?
is there a difference in trailing arms in a lwb and swb? I have a mint set of trailing arms off a lwb, and the trailing arms on my swb are kinda rough(rusted). Can I swap these out or is there a difference in length or anything else I should look for.
too many projects: 61 biscane 67 swb(shaved) 73 Fiat spider 124 Sport 84 Pontiac Grand Prix 86 olds cut. sup. |
10-16-2003, 10:27 AM | #2 |
I understand they are the same. The mount is just in a different place on the frame.
Swap em!
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
10-16-2003, 10:50 AM | #3 |
I agree, the mounting points on a SB is forward under the cab, as the LB is behind the cab about a foot.
72 LWB - Hugger Orange 350/350 3.73 Next; 335hp GM Crate |
10-16-2003, 11:40 AM | #4 |
the trailing arms are the same. i'm using the ones off of a lwb on a swb frame. work great.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
10-16-2003, 06:02 PM | #5 |
Dad's little helper
thanks for the info, I will try that over the weekend and see what happens.
