Old 02-17-2017, 08:02 PM   #1
mytruck1949
1949 Chevy 3600 Wiring
Guys
need some help here. I am sure it is pretty simple but a rookie to wiring on this old truck. Its a 6volt system. I have 2 wires that ran down the drivers side frame but then draped down to the ground. I have been able to tap into 1 wire that shows 6 volt and run it pig tailed to both lights. Pull the headlight switch on and I have lights. whohoo.
Now onto what I do with the Black wires from each tail light?
Also any clue what the second wire is that ran in tandom with the hot wire. I put the meter on it and I get nothing. I had the misses step on the brake and nothing.
any advice you have would be great.
mytruck1949 is offline   Reply With Quote
Old 02-17-2017, 09:38 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 1949 Chevy 3600 Wiring
According to my book you should have a black wire for tail light and a orange wire for brake lights coming from your fuse block..that is if somebidy didn't rewire it at some point in time
Old 02-17-2017, 09:46 PM   #3
mongocanfly
Post Whore
Your park/tail light wire should be violet..
