02-18-2017, 01:12 AM | #1 |
'64-'66 c10
Question,
Were armrests ever available as an option for these cabs? Thanks. |
02-18-2017, 06:04 AM | #2 | |
Re: '64-'66 c10
http://www.classicindustries.com/sho...ods/?q=Armrest |
02-18-2017, 08:08 AM | #3 |
Re: '64-'66 c10
There were 2 different styles. The basic 1 piece molded, then the 2 piece which has a plastic color coded bottom and the vinyl top. My 65 Suburban only has 1 of the 1 piece units, on the driver door, that was originally fawn. Replacements are only black and red.
Can someone correct me if I am wrong on the 2 piece units? Thanks |
02-18-2017, 07:56 PM | #4 |
Re: '64-'66 c10
My 65 Suburban has just the one on the drivers door and its the deluxe one. I have a set of door panels that have the factory holes in them from a 66 I scrapped. I use them as a template to ad holes to other sets.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-18-2017, 09:58 PM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
Re: '64-'66 c10
I believe the drivers was required and the passengers was an option. Like said before, there was a standard and a deluxe armrest available.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-19-2017, 01:04 AM | #6 |
60-66 Nut
Re: '64-'66 c10
You will also likely need to install the 1/4"-20 cage nuts into the inner door to anchor the arm rest to. If I remember correctly there are 2 sets of square holes in the inner door as possible locations to mount the arm rest.
02-19-2017, 08:04 AM | #7 |
Moderator
Re: '64-'66 c10
Two Piece Arm rests in various colors: http://www.bowtiebits.com/store/stor...Category_ID=75
The Truck Shop in Orange has the deluxe arms rests in three colors:
