02-18-2017, 04:37 PM | #1 |
Motor Mounts for 327 in a '62
So I found some motor mounts online a while back. I was told they fit 62 just fine but will need some holes drilled into the crossmember and the frame.
Has anyone put motor mounts in a 60-62? Just looking at the mounts and resting them on the frame and crossmember doesn't look right. Is there more modification or spacers needed to get everything to line up right? Sorry if this is a real amateur question. I've got all the body parts off the front end. Looking to clean up the frame, crossmember, and upgrade/replace what I can of the T Bar suspension. Finally decided to stick with what I have and just upgrade to disc brakes and be done with the suspension. Really want to get this truck on the road this year. I'm in Wisconsin so I only have a few months to drive each year. . |
02-18-2017, 11:32 PM | #2 |
Re: Motor Mounts for 327 in a '62
It should look like these...from the classified section and not mine.
MusicMan70 1961 GMC Suburban |
02-19-2017, 12:26 AM | #3 |
My original '62 283 mount is a big U shaped saddle mount bolted onto the front of the engine
Then there are 2 additional mounts, one on each side of the bell housing. |
02-19-2017, 12:56 AM | #4 |
Ah, I just learned something, Thanks for the clarification.
02-19-2017, 01:13 AM | #5 |
60-66 Nut
If the mall block was coupled to a bellhousing and a manual trans, the front saddle was used. If the engine was coupled to an auto trans, the side mounts shown in the pic MusicMan70 posted were used.
I believe the OP has a set of aftermarket engine mounts. To my knowledge none of the aftermarket engine mount brackets are made specifically for the shorter '60-'62 frames. They will require a spacer on top of the frame. I just don't know how thick. The best fitting engine mount brackets I have found for the '60-'62 frames are the '67-'72 small block engine mount brackets. I believe they may still require a spacer of about 1/4", but I would tray them without first.
02-21-2017, 02:27 PM | #6 |
On my 62 I used the 63-66 engine mount brackets and they did require a 1/4 inch spacer at the top.
Here are a few photos for visual reference. The first one is my 62 with mounts from a 65. This one is test fitting a set of 67-72 mounts. You can see the height differences between the two. This one is a pic of the front saddle 60-62 v8 mount that CaptainFab mentioned.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
02-22-2017, 11:35 PM | #7 | |
Both those pictures are a 60-62 frame correct?
02-23-2017, 12:14 AM | #8 |
Correct.
02-23-2017, 01:07 AM | #9 |
this one has been around for quite a while and many have used it
http://67-72chevytrucks.com/vboard/s...d.php?t=369663 this was also in the FAQ section. there is a lot of info there for you ron |
