Old 02-18-2017, 07:20 PM   #1
zicc1835
zicc1835's Avatar
DIY Powder Coating
long 6 year story ....bought the PC kit from Eastwood 6 years ago used it for the first time last night did my engine stands ....I been bit by the bug now . Does anyone have experience with coating front end steering parts i have all moog everything to rebuild steering complete... my question is the tie rod ends etc. come loaded with grease do i bake that out bath & clean them plug and tape the threads anybody DIY this they need to be coated one way or another or they will turn to rust.... would like to know if it makes any sense to PC these parts
thanks
Jess
zicc1835 is offline   Reply With Quote
Old 02-18-2017, 08:43 PM   #2
jocko
jocko's Avatar
Re: DIY Powder Coating
No real point to pc threads - I'd just keep em oiled every once in awhile. PC is nice - and that looks great. I'm always torn - it's easy to scratch, so be careful!
Old 02-19-2017, 08:49 AM   #3
zicc1835
zicc1835's Avatar
Thanks Jocko
i can and will tape up threads and put grease on them after I coat them, just wondering if anyone has put them in oven sweated the grease out clean them up and prep
at any rate painting or powder coating them you have to remove the grease that the manufacturers installed just looking to see if anyone experienced powder coating these ?
Old 02-19-2017, 09:24 AM   #4
Yes, you have to break the tie rod ends down and tape the threads. As you probably figured out, coating on threads will cause them to not fit the nut and all it will do is pop off as you tighten. I've never done my own but have been having a place do mine since the '80s, so I've gotten an education. I'm friends with the owner and he has educated me on a lot of it, from all the various pieces I have had done. People say not true, but he told me they only do individual pieces. The tie rod end has moving parts. Maybe it can be done, but when the parts move the coating will have to break and won't that start the deterioration process? Powder coat is a shell and once compromised will hold in water and the coating can become unbonded and come loose as a shell. I would tape up the ball socket and stud so the only thing coated is what is exposed. That's all that matters.
Old 02-19-2017, 09:26 AM   #5
James the III
I plan on taking my large dead freezer that is 6' tall and 3' wide and pulling the plastic inner and lining it with steel and making it an oven..
James the III is offline   Reply With Quote
Old 02-19-2017, 10:03 AM   #6
zicc1835
zicc1835's Avatar
"Tapping the ball joint and stud"thats the answer i was looking for thank you very much ....what do you think about sweating the grease out in the oven? my plan is to cook them get the grease out wash them good cook again tape up like you said and apply powder and cook the sleeves are another story ...to much going on there may have to paint them....maybe as a rookie I'm getting out over my skis
and should just paint it all and hone my skills on straight forward parts
Old 02-25-2017, 09:08 PM   #7
zicc1835
zicc1835's Avatar
any suggestions on how to hang coil springs for coating then baking
Old 02-25-2017, 09:55 PM   #8
CrewCab59
CrewCab59's Avatar
It's a a good idea to clean and heat to make sure no grease/ oil is left behind and I wipe down again after cools down.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 02-26-2017, 07:55 AM   #9
GR8-68
GR8-68's Avatar
Something here just does not sound like a good idea to me. I think I would stick to the standard paint, I used semi gloss black wheel paint on mine as it bonds great and holds up well. Stick to the easier parts Jess
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 02-26-2017, 08:52 AM   #10
zicc1835
zicc1835's Avatar
I know you are right Larry I'm going to paint the steering parts . what you think about me tac welding a wire hoop to each end of the spring to hang it PC and then grind off hit those spots with a touch of POR15?
Old 03-04-2017, 10:07 PM   #11
zicc1835
zicc1835's Avatar
built my own oven today for the longer c-members ....only need 400 degrees for 20 mins LOL ...will see how she works tomorrow
Old 03-04-2017, 10:40 PM   #12
RUN GMC
RUN GMC's Avatar
More pics of this incredible idea...........
RUN GMC is offline   Reply With Quote
Old 03-05-2017, 08:21 AM   #13
GR8-68
GR8-68's Avatar
You my friend are a genius So now we want to see pics of the end product
Larry
"Project 68"
paypal.me/ldgrant
Old 03-05-2017, 09:55 AM   #14
88fordf150
88fordf150's Avatar
Just hang it with a heavy gauge wire. I like to use drop ceiling suspension wires.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 03-05-2017, 10:21 AM   #15
projectking
projectking's Avatar
Get a roll of tie wire http://m.homedepot.com/p/Weyerhaeuse...5337/202094311
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 03-05-2017, 09:33 PM   #16
zicc1835
zicc1835's Avatar
I'm pleased my oven works well on the right is the rear most C-member i used a Satin ...is a little to flat for me so i added some semi -gloss to the satin and coated the clamshell ( middle ) and got the desired results. The SB engine stand is semi gloss and the bracket that holds the A-arm cross shaft was done professionally and the finish i am looking for so I mixed my own and nailed it ...............
Old 03-06-2017, 07:05 AM   #17
GR8-68
GR8-68's Avatar
Very nice Jess, you seem to be closing in on me
Larry
"Project 68"
paypal.me/ldgrant
Old 03-06-2017, 08:26 AM   #18
zicc1835
zicc1835's Avatar
your moving at light speed ....and inspiring, its going to be fun to follow, best I could do now is bring up the rear or retire
