Old 02-18-2017, 09:00 PM   #1
awhite4557
awhite4557's Avatar
1972 1 ton Wrecker
I'm starting a new project (as time and money allows). I purchased a 1972 C-30 1 ton cab and chassis to start with. I also purchased a 1991 GMC 1-ton roll back wrecker with a 454 5 speed. I also purchased a 2002 24 valve Dodge Cummins with a 5 speed transmission. My goal is to swing the 1972 cab/front end onto the 1991 frame which is already stretched with the aluminumn roll back wrecker bed and then install the cummins engine and transmission.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 02-18-2017, 10:35 PM   #2
Re: 1972 1 ton Wrecker
Sounds like a great plan. I've yet to do a Cummins swap, but I remember when they came out thinking what great donor engines these will be. Now I see the day there will be more 12 valve Cummins in other vehicles than Dodges. Might already be true.
Old 02-18-2017, 10:48 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
I can't wait to see this one. I'm planning to swap a 12 valve into my K/20 a few years down the road.
Tyler
57taskforce is offline   Reply With Quote
Old 02-19-2017, 08:26 AM   #4
Boog
laying low
Boog's Avatar
It's sort of got that "towmater" look about it.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 02-19-2017, 08:59 AM   #5
zicc1835
zicc1835's Avatar
subscribed
zicc1835 is offline   Reply With Quote
Old 02-19-2017, 09:33 AM   #6
People need to add "Cummins" to "12-valve" when referring to them. I mean, a 250 is a 12-valve and so is a 292, and about any 6cyl out there. Don't mean to insult, but it just sounds ignorant to me, especially when these trucks came with 12-valves and they weren't Cummins diesels
Old 02-24-2017, 01:45 PM   #7
Leangreen72
I swapped a cummins "12 valve" into my 1970 k20 a couple of years ago...used a 1990 model 3/4 ton dodge for a donor..swapped in the Dana 60 front and 70 rear..has 3.08 gears and used the 727/205...one of my favorite trucks...had 4:56 gears,350, 4 speed and was only good for 6-7 mpg...now it cruises right down the road getting 16-17 mpg...
Leangreen72 is offline   Reply With Quote
Old 02-24-2017, 01:57 PM   #8
Leangreen72
Old 02-24-2017, 08:24 PM   #9
72 tigger
72 tigger's Avatar
I bought a rolled over 02 dodge 4x4 with a cummins in 03 & used the entire chassis under my 72 body. Been using it as my DD/work truck for over 13 years & very happy with it
72 tigger is offline   Reply With Quote
Old 02-24-2017, 09:45 PM   #10
57taskforce
All about them K’s
I'm just waiting for the right 12 valve truck to come up for sale so I can scoop it up. They are still pretty pricey for there age around here.
Tyler
Old 03-01-2017, 12:11 AM   #11
awhite4557
awhite4557's Avatar
This is the engine and transmission for the project. Its a 2002 24 valve cummins with a 5 speed manual transmission.
1971 Chevy Chevelle
Old 03-01-2017, 12:14 AM   #12
awhite4557
awhite4557's Avatar
This is the wrecker I bought for the frame and bed. It's a 1991 GMC 1 ton with a 454 and 5 speed manual transmission. The bed is a Century 17 foot roll back aluminum wrecker bed.
1971 Chevy Chevelle
Old 03-01-2017, 12:51 AM   #13
57taskforce
All about them K’s
That is gonna be a really cool truck!
Tyler
Old 03-01-2017, 03:33 AM   #14
James the III
What are your plans for front springs??
As the oil burner is double the bbc weight
James the III is offline   Reply With Quote
Old 03-02-2017, 12:16 AM   #15
awhite4557
awhite4557's Avatar
I'm not sure of the difference it will make, I was going to install the cummins and make adjustments from there. I plan to do some research as well since I am planning to restore the 72 and make a classic hauler out of it, updating the front suspension with new parts.
1971 Chevy Chevelle
Old 03-02-2017, 01:15 AM   #16
57taskforce
All about them K’s
The 5.9 is about 500 lbs more than a big block. I'm sure you can come up with something,
Tyler
