02-19-2017, 08:04 PM | #1 |
Minor score at the yard, Part Deux
Thanks to Andy I found ABUNCH of the wiper mounted washer nozzles, so they'll be going on "the Mistress" soon.
Another cool item I found was a retractable under hood light (from a 97 Tahoe). It'll work better than the Mercury switch one I have now |
02-19-2017, 10:14 PM | #2 | |
Old member
Re: Minor score at the yard, Part Deux
Cool! If you have a electric garage door you need to grab the home link out of a GM are Ford they are all the same. You hook a 12 volt and ground up and program it to your door.
02-19-2017, 10:34 PM | #3 | |
Some of the older Homelink remotes won't work on some of the newer openers without buying a "repeater". We've got an '02 Merc Grand Marquis that doesn't play well with our new Chamberlain opener. Just a heads up..
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
02-19-2017, 10:45 PM | #4 | |
Old member
Here are the 2 I have and both work fine. The one in the ash tray doesn't have as much reach but I figure it's because it's inside the ash tray.
