Leaky diff and how to remove undercoat efficiently?
My dad and I took the bed off yesterday and noticed the rear diff was leaking from just about every place it could.. how should we go about that?
Also, we are going to either POR 15 the underside of the bed or new undercoat. What's the best way to remove what's there already? I am going at it with a scraper and it is very tiring and time consuming but the fastest and cleanest way I've found. Thanks!
1978 Hawaiian Blue GMC 454/Tremec TKO 500 BUILD THREAD |
Re: Leaky diff and how to remove undercoat efficiently?
If you have one of those little torches that go on a little propane tank it helps to warm the stuff up just ahead of the scraper as you go. Depends on what the stuff is. Might help you out
-Cody |
If you have access to a decent compressor, I'd try a needle scaler to peel the undercoating off.
