Old 02-20-2017, 05:21 PM   #1
Bullett
62' c10 grill removal
Need to remove my grill for my repaint. Is the easiest way to do this to remove the headlight/headlight pod that the grill is riveted to or to drill out the rivets that hold the grill on? I didn't really study it yet but looks to be easier to remove the headlight pods? Thanks....
Bullett is offline   Reply With Quote
Old 02-20-2017, 09:10 PM   #2
Fredthecat
Re: 62' c10 grill removal
I know 1964 C10 grill simply unbolts as a unit with headlights and wiring in place, requires no rivet removal.
Disconnect headlight 2 wire plug near voltage regulator (green and tan wires).
remove 3 bolts from under fender and 1-2 though grille.
lift off.
Fredthecat is offline   Reply With Quote
Old 02-20-2017, 10:40 PM   #3
Bullett
Ok, I suspect that is what I need to do. I guess it almost seemed to easy. Thanks.
Old 02-21-2017, 02:31 AM   #4
argonaut
argonaut's Avatar
4 bolts per side. Three from the back side of the grill support below the radiator support in the wheel well. 7/16" bolts uses 1/2" socket. One you access from above. Remove the wing panel from the top of the grill support to radiator support. I think that one is a 3/8" bolt needing a 9/16" socket. Unplug the three prong connector passing through the radiator support next to the horn relay and voltage regulator.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
