Old 02-20-2017, 07:24 PM   #1
Mustang2xvt
No start 99 gmc yukon!!!!!
Have a 99 5.7 gmc Yukon... Was running fine, shut it off then the next morning tried starting it up and nothing. Turns/cranks wants to start but nothing, checked it for codes and have none. The fuel pump, plug wires, distributor, cap and rotor were replaced maybe 6 months ago. Holds fuel pressure( key on jumps to 60 psi then drops to 55psi when the relay clicks on and stays there), the pump and relay come on, have spark at all plug wires.
Thought the timing chain had jump but everything is at tdc. I swapped out the spark plugs, starter, crank sensor, battery and did a compression test this morning with cold engine(since it will not start) and here are the numbers
#1 150 #2 150
#3 170 #4 110
#5 85. #6 90
#7 150 #8 75
Would these low of numbers cause it not to start?
Mustang2xvt is offline   Reply With Quote
Old 02-22-2017, 07:58 PM   #2
Mustang2xvt
Re: No start 99 gmc yukon!!!!!
Nobody....? Really need help!
Old 03-02-2017, 05:54 PM   #3
Moose Monkey
Moose Monkey's Avatar
Just saw post. Have 03 pickup, numbers good enough to run. Ran fine before?
Moose Monkey is offline   Reply With Quote
Old 03-03-2017, 08:20 PM   #4
95 S_Trucker
95 S_Trucker's Avatar
Ask a mod to move this to the 88-98 section(gmt400).
Check for spark at all the cylinders. Most likely it's a cap/rotor problem, since you have fuel pressure and compression.
95 S_Trucker is offline   Reply With Quote
Old 03-04-2017, 12:59 AM   #5
Mustang2xvt
Sorry... Newbie here and I didn't realize I posted this the wrong forum. And yes it was running fine, shut it off and it didn't want to start the next morning. And it's just been collecting dust since. I will try a new cap / rotor, hopefully that's my problem.
Old 03-04-2017, 09:30 PM   #6
Moose Monkey
Any luck? Spark a little funny on them sometimes. Had one the air gap to wide on pickup , wouldn't fire to fuel fouled plugs, but was still nicely arc. Only ran first start with new plugs. Will drive you nuts.
Old 03-07-2017, 08:52 PM   #7
Mustang2xvt
Ok... Swapped out the cap/ rotor and still will not start, to say I was disappointed would be an understatement....
Old 03-07-2017, 10:38 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
6&8 either are leaking compression through a valve, or have worn their rings out. Thats a very large discrepancy between individual compression tests.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-07-2017, 11:56 PM   #9
Mustang2xvt
Wouldn't this have cause a misfire code prior to it not wanting to start?
Old 03-09-2017, 10:37 AM   #10
Moose Monkey
Just for giggles, unplug some main pieces and see what codes come up
Old 03-19-2017, 04:42 PM   #11
Mustang2xvt
On the urging of my neighbor, I bit the bullet and bought another cap/rotor. Wouldn't you know it the sucker fired right up! But now it vibrates alot espcially when you put it in drive. Ran it for codes and none came up, maybe a misfire?
Old 03-19-2017, 04:44 PM   #12
Mustang2xvt
Btw... Wanted thank everyone for the help!
Old 03-19-2017, 08:12 PM   #13
Moose Monkey
That's great now recheck fire order , just for giggles
