02-20-2017, 07:48 PM | #1 |
Dana 44 rear axle backing plates (Pictures)
Since the PO welded the backing plates on the end of the diff tube I was wondering if anyone had any pictures of a Dana 44 rear backing plate and how it is attached the right way?
02-20-2017, 08:13 PM | #2 |
Re: Dana 44 rear axle backing plates (Pictures)
Here is what the PO did with the backing plate (welded it on)
02-20-2017, 10:29 PM | #3 |
It is supposed to be bolted down with everything else to the flange
02-21-2017, 12:50 AM | #4 |
There are special "half moon" head type bolts that are used here as full size bolt heads don't fit next to the tube.
02-21-2017, 08:52 PM | #5 |
chewychevy67 did you find those bolts new somewhere?
02-22-2017, 12:11 AM | #6 |
No I did not. I reused the ones on my truck. The head looks like this with a lock nut on the inside. Just a pic I found on the net not the actual bolt. I suppose you could find them new.
