Old 02-21-2017, 02:14 AM   #1
Marcus4800
Removing Rust From Bolts
I just finished removing all the body parts from my 63 C10 stepside shortbed rebuild. You can imagine the amount of rust on all the nuts and bolts after 54 years in the weather. My son who works at a cooler shop (radiator on oil coolers for industrial engines) I ask him when they vat stuff does it remove the rust and he said no but it does remove the paint. So I asked how they get the rust off and he said muriatic acid. So I knew I had a gallon of the acid so I pored a little in a plastic coffee container about 1-1/2 deep. Now each time I take a set of bolts off I put them in a zip lock baggie and write on the bag what they go to. So I took a set of bolts and dropped them in the acid for about 30 minutes and when I took them out I was totally blown away. They looked like you took them out of a new box bolts. Now I doing all my nuts and bolts. Now some bolts that are bad you know that real quick you find bad spots that you couldn't see before you soaked them. When I take them out of the acid I drop them in paint thinner to neutralize the acid and let them air dry before I put them back in the baggie. Y'll probably already knew this but I didn't and thought I would share for those like me who didn't. Muriatic can be bought at any swimming pool supply store or the home improvement stores in the pool supplies. ####CAUTION#### don't get this stuff on you it burns I encourage to wear safety eye and hand protection. I use the throw away plastic glove when working with this. Hope this helps a few folks....
Marcus4800 is offline   Reply With Quote
Old 02-21-2017, 02:18 AM   #2
Captainfab
60-66 Nut
Re: Removing Rust From Bolts
I use white vinegar to remove rust and mill scale from new steel. I neutralize the parts by rinsing them in a baking soda and water solution. The muratic acid does work but I prefer an acid a little milder.
Old 02-21-2017, 02:25 AM   #3
Marcus4800
Thanks I'll give that a try to.....
Old 02-21-2017, 07:56 AM   #4
PGSigns
PGSigns's Avatar
I have been using Metal Rescue and it works pretty good. Got a plastic 2 gallon bucket with a lid and a plastic strainer. Got a gallon from the parts store.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-21-2017, 09:54 AM   #5
jayoldschool
Moderator
Vinegar works, and is dirt cheap. Buy a few big jugs at Costco, dump in a bucket. Pour in the parts, take out a couple days later, rinse. Parts will look new.
jayoldschool is offline   Reply With Quote
Old 02-21-2017, 12:38 PM   #6
cg285
i buy new hardware and go back to work
cg285 is offline   Reply With Quote
Old 02-21-2017, 12:46 PM   #7
Cape Codder
Cape Codder's Avatar
I have also started using vinegar just because it is less hazardous. It is best to rinse any part treated with acid to baking soda water rinse to neutralize. as has been stated and told to me by a science teacher customer of mine.
Cape Codder is offline   Reply With Quote
Old 02-21-2017, 12:48 PM   #8
MikeB
MikeB's Avatar
Sounds like I should try muriatic acid.
I have been using Evapo-rust, which works pretty well. Just clean off the grease and loose rust, then drop the bolts into plastic container with enough liquid to cover them. Then check the bolts every few hours.
One nice thing is it's kind of like a jelly, so can be used on vertical surfaces that you can't drop in a container.
Wish I had a picture of a bracket I soaked in Evapo-rust. One corner was part in/part out of the liquid, so there was sharp line that showed a huge before/after difference.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-21-2017, 01:01 PM   #9
Cape Codder
To do large sheet metal parts wet a few layers of paper towel and let it sit for a while on the part, You may have to keep adding whatever acid you are using if heavily rusted.
Old 02-21-2017, 01:17 PM   #10
MikeB
MikeB's Avatar
Some of the bolts and nuts used by GM are hard to find new. For example, the nuts, and sometime bolts, have flanged shoulders instead of having to use washers. Also, some bolts are only partially threaded, so the un-threaded part can serve as a smooth surface for a bushing. An example of this is an exhaust manifold bolt that's 3-3/8" long with only 10-12 threads on the end.
However, if you have really good hardware store in your area, you may find they carry at least some automotive-type bolts. In the Dallas, we have Elliot's Hardware and BA Industrial. There are also a bunch of good on-line stores, such as Bolt Depot.
Mike
Old 02-21-2017, 02:14 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
x2. I've been using stainless.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-21-2017, 05:34 PM   #12
MikeB
MikeB's Avatar
Yeah, me to on some things. Attached the tailgate latch on my 69 pickup using stainless hardware back in the early 1990s, and the bolts are still shiny!
Mike
Old 02-21-2017, 09:23 PM   #13
jocko
jocko's Avatar
I've gone away from muratic acid. It's simply not very safe. As a kid I poured it on parts in a little metal jiffy pop base. Of course I knocked it over and it was the China Syndrome on my dad's freshly blacktopped driveway... It didn't end well. To top things off, I left a bottle open on his workbench once - and all his exposed tools dulled and looked like crapola. So, let's just say I learned my lesson! Ha. Ouch. Can only imagine if one little splash of it got past the safety glasses. Anyhoo.. I use evaporust, but I gotta try the vinegar approach just for the cost savings.
Old 02-27-2017, 03:43 AM   #14
Heater63
Heater63's Avatar
You might want to read about using acids on steel and hydrogen embrittlement.
I would not use HCl (muriatic) acid on fasteners.
I highly recommend Evaporust. It is EDTA, which is a chelating agent. Very safe, and works very well. It resembles antifreeze on appearance. Tractor Supply (using a coupon) and WalMart.com are my cheapest sources. You can use it over and over until it is black.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 02-27-2017, 09:40 AM   #15
vin63
It's Better With Nitro
vin63's Avatar
I also do not use acids, etc. on fasteners. I'm a reloader, so I use my tumbler to clean. If they are bad, I replace fasteners.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-27-2017, 10:08 PM   #16
VictoriaHardware
VictoriaHardware's Avatar
Very important- I have run into this. It wrecks Grade 3, 5, & 8 bolts and springs. Makes them soft. They stretch till they break.
VictoriaHardware is offline   Reply With Quote
Old 02-27-2017, 11:14 PM   #17
DakotaKid
harbor freight abrasive Tumbler bowl. best thing ever. throw em in, forget about em for a few hours, come back they are clean.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
