Old 02-21-2017, 09:36 AM   #1
FRCvette
wheel not centered in fender
Lowered my truck in rear 4" using coil springs. I installed shock relocater brackets and installed adjustable track bar. Now the passenger side wheel is one inch back in wheel well. Can this be fixed by adjusting track bar? If so how do I adjust. Drivers side is perfect.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 02-21-2017, 10:32 AM   #2
sprint_9
sprint_9's Avatar
Re: wheel not centered in fender
I would focus on getting the rear end square with the frame, along with the rest of the suspension including the front wheels. If youve done this already then maybe the box isnt square on the frame.
I think I've read on here elsewhere where the wheels wont be centered front to back, but i thought they sat farther foward, dont remember for sure though, either way I would think that it would be relatively equal on both sides.
sprint_9 is offline   Reply With Quote
Old 02-21-2017, 11:04 AM   #3
jgr
Your Starting point will be measuring your wheelbase it should be 115 inches for a short bed
jgr is offline   Reply With Quote
Old 02-21-2017, 02:13 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
^ I'd start here. You'd be surprised how much 'adjustment' there is in the U-Bolts/trailing arms to just getting the rearend square in the frame. If that is all good, I'd look at making sure the bed is right. It's possible things moved around on you or the rear thrust alignment got off when you did the rear suspension work - I assume you unbolted the u bolts to install the lower shock relocator brackets? Or maybe it was off before and now the bed is closer to the tire and you notice it now? Just thoughts.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-23-2017, 09:55 AM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: wheel not centered in fender
I had the same thing happen to me, but I had both my upper control arms swapped left for right, found this out while having the alignment done.they couldn't get the caster settings to adjust out enough, so my wheels were located further back in the wheel wells. Hope your issue is as simple as mine was.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 02-23-2017, 01:06 PM   #6
cdowns
cdowns's Avatar
if it is a short bed have you verified that it is in fact a factory shortbed and not a homemade one
Old 02-23-2017, 03:43 PM   #7
FRCvette
Thanks all. Guess I have some measuring to do. It is a factory stepside.
2004 SSR
2013 Silverado swb
