02-21-2017, 10:44 AM | #1 |
Fuel rail setup question
I'm in the process of getting parts gathered up in anticipation of the LS1 swap into my '70 K/5....
I created a rendering of the fuel feed set-up after looking at several pictures posted by members here.... My main question is...would it be necessary to add a schrader valve at the end...in order to purge trapped air from the rails....?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
02-21-2017, 11:47 AM | #2 |
Re: Fuel rail setup question
I do not have one on mine and it works fine.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-21-2017, 11:47 AM | #3 |
You don't need to purge the air out of the rails, it will do that when the injectors open. If you didn't have a permanent gauge on the rail it would be handy for hooking a gauge up to it though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-21-2017, 09:09 PM | #4 |
When I did my LS swap with a BBK intake and aftermarket fuel rails I put a "t" in the fuel line feeding both rails on the back side of the fuel rails. Then kind of hid the fuel line behind the intake. I haven't done the Schrader valve or pressure gauge.
02-22-2017, 08:19 AM | #5 |
I considered that as well....it looks to be foolproof in just about any configuration...thanks to all who responded.
02-22-2017, 11:39 AM | #6 |
I thought about doing mine this way as well, have the crossover on the back, and nothing on the front
02-22-2017, 12:55 PM | #7 |
I personally like having both, but not necessary.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-23-2017, 09:29 PM | #8 | |
