Junior Member
![]() Join Date: Oct 2016
Starter wiring question
Hi all! I am changing from a manual trans to a T350in a 67 C10.
The stock starter is a 3 bolt one that mounts to the bellhousing, and has the big battery cable coming from the battery, and 2 small studs with 1 wire on each. The new starter came with the trans from a 71 GMC C10. It bolts to the block, and only has 2 posts... The big battery one, and 1 small stud. Any idea on how to wire this up? Thanks! |
Re: Starter wiring question
The small "S" terminal is your start terminal (goes to ignition switch, hot is start) the small "R" terminal is for ballast resistor (points type distributor) if you have electronic ignition you don't need to use this one. If you do, this one runs to your coil.
Junior Member
It has already been swapped to an HEI distrib, it is spliced into the wiring harness by the firewall from the previous owner. They did some "Odd" wiring! lol I still have to figure out why there is no headlights and tails... The brakes work, but a lot of other wiring is patched and stuff!
#4 | |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
If you still have the old points style ignition then you can put the other wire, (usually Yellow) on the same post and install a diode in series with the wire to allow you to get the 12 volts during starting and to prevent the coil voltage from feeding back to the starter when the key is on.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
