Need upper clutch push rod #3907877 for '68 C10
Anyone know where I can find one?
![]() Join Date: Jun 2005
Re: Need upper clutch push rod #3907877 for '68 C10
Got a pic?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Yes, it's like the one in the picture (if the attachment worked).
I bought a reproduction from a place but it was the straight one. That's all that seems to be available new. It was less than $20 which seems reasonable. |
![]() Join Date: Feb 2002
That's the V8 one, with the dogleg. The L6 upper clutch rod had less of a bend, but the thing LMC tries to sell is neither.
The LMC one is the one I bought. In their pictures it's for a six not a V8, but I tried it anyway. Paid as much in shipping (to me and back to them) as it cost. It's not even close.
#6 | |
The V8 ones weren't so hard to find when I put a 350 in my '71 Jimmy... [ Now LMC even copied my machinists'heim joint idea, but for large dollars.] The OEM V8 dogleg rod was cast in pot metal, so it doesn't take to welding very well. A good blacksmith could hammer out the perfect part. Too bad I don't know any.
![]() Join Date: Mar 2014
If youre talking about the one from the pedal to the crank on the frame, no one reproduces them it seems. I had to weld onto mine to reshape the wear.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
#8 | |
I'd like to find a worn one cheap so I can do that and have it on hand. |
The upper rod would connect the pedal to the bell crank or z-bar I believe.
![]() Join Date: Dec 1999
There are a couple on eBay that come withe the pedal assembly also, probably driving the cost up.
http://www.ebay.com/itm/67-72-chevy-...-/272564838612 http://www.ebay.com/itm/67-72-CHEVY-...-/252779849188 Then there is the $300 NOS one, that I won't bother linking. |
#11 | |
I tried eBay a couple of months ago and the $300 one was all I found. These two listing are better but still steep. |
It is the one from the pedal to the z-bar. I have one somewhere but it might be worn out, as I presume yours is.
#13 |
#14 |
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by LockDoc; 04-22-2017 at 12:28 AM. Reason: WTB by non premium member |
#15 |
I have one like the one in the above pic (flat sided)
#16 |
If you need any further assistance with that please contact any Admin for help. Last edited by LockDoc; 04-22-2017 at 12:27 AM. Reason: WTB by non premium member |
