Old 02-21-2017, 08:27 PM   #1
ken4444
Opinions on this '71
This truck is pretty rough and has the usual problems in the usual places, but I'm eager to get your opinions on any obvious challenges with rebuilding it. My intent would be to do a thorough frame-off rebuild. The biggest challenge looks like it would be replacing the rotted sheet metal. It's going to need a new roof, cab corners, rocker panels, bed floor, lower doors, and probably more. The engine may be the strongest element but it hasn't run in a few years.
I will post a second batch of pics in a second post.
ken4444 is offline   Reply With Quote
Old 02-21-2017, 08:35 PM   #2
1968aj
Re: Opinions on this '71
my honest opinion---that is about a 3 or 4 hundred dollar parts truck in Houston.
1968aj is offline   Reply With Quote
Old 02-21-2017, 08:38 PM   #3
jocko
jocko's Avatar
Originally Posted by ken4444 View Post
I'm eager to get your opinions on any obvious challenges with rebuilding it ... going to need a new roof, cab corners, rocker panels, bed floor, lower doors, and probably more. The engine may be the strongest element but it hasn't run in a few years.
I think you just answered your own question. The rust looks pretty invasive, I'm afraid to say. The "and probably more" is the big question - and, unfortunately, "hasn't run in a few years" is not a strong point. Completely understand why you are considering the project - swb, needs a little work, etc. But, have to ask if you're comfortable with that level of sheet metal repair and your experience level? This is a pretty varsity job in my honest opinion. I believe a resto would be a challenge, but a hot rod / resto-mod is in the realm of the possible. Don't get me wrong - anything can be done and it absolutely can be fully restored, the issues the cost and time to do so.
Just so I'm clear - do you already own this truck or are you considering it?
Old 02-21-2017, 08:57 PM   #4
ken4444
... But, have to ask if you're comfortable with that level of sheet metal repair and your experience level?
Great questions. I do not own this truck. I have been looking for such a truck for a project and this is the only SWB truck I've seen in my area recently.
I do have some experience doing sheet metal body repair although I am not an expert by any means.
My intent with this truck would be to build a reliable daily driver that also looked good. My latest total is about $13K in parts and work not counting the price of the truck itself, and that's IF the engine and tranny are good, however it's the unknowns that'll get ya, right?
Old 02-21-2017, 09:06 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I'd pass on that rig. That is a basket case.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-21-2017, 09:09 PM   #6
jocko
jocko's Avatar
Whew. Run away. There are better deals out there by far.
Old 02-21-2017, 09:33 PM   #7
robs71
robs71's Avatar
if you are considering doing a frame up rebuild as your first post states and are prepared for the challenge and are not in a hurry to get on the road and want to do a short bed here is another view of the truck..if it is a real short bed,frame is good other than surface rust,suspension is intact and useable,vin plate is intact matching title..it is worth a few hundred$ just for parts.Maybe truck could be bought without motor..next keep your eye out for a long bed with a decent cab and possibly a complete good running truck for a reasonable price and start swapping over...seems like the body of the truck in pictures is pretty far gone but the rolling frame would be a start if you had intentions of going all out.
robs71 is offline   Reply With Quote
Old 02-21-2017, 09:59 PM   #8
ken4444
Gary
Originally Posted by robs71 View Post
....seems like the body of the truck in pictures is pretty far gone but the rolling frame would be a start if you had intentions of going all out.
Thanks for all of the input. Here are a few more pics although everyone is probably thinking that we already know how bad this thing is.
My worry is that even if I could buy this truck very low cost, the money isn't really the issue: the time to repair of the sheet metal is the big part of this project.
Old 02-21-2017, 10:08 PM   #9
tap500
I'd pass on this one. Only advice I can give is to look for the the the most complete and rest free truck you can find. It will be cheaper and take less time in the long run.
tap500 is offline   Reply With Quote
Old 02-21-2017, 10:35 PM   #10
saxart
saxart's Avatar
What scares me the most about that truck is that every part on it has been "touched' by someone in the past. Many times that equates to more work than it's worth.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 02-21-2017, 10:49 PM   #11
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Opinions on this '71
i agree 100%
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-21-2017, 10:49 PM   #12
davepl
davepl's Avatar
Does it have a cross-ram Chevrolet HemiWedge from the factory? Otherwise I'd run away.
In all seriousness, if this were a big-block short-box AC truck with speed warning and Margot Robbie was the current owner, I'd go look at it. But it's not.
There are WAY better trucks to start with. Find yourself one! Especially if you're going to do a frame-off rebuild, that's a 3-4 year fulltime project, you might as well spend it with something complete and unmolested.
Now if you're doing a complete custom and don't need the stock parts and you're going to tub it and do a bunch of custom metal work anyway, then maybe.
That's a lot of rust and nonsense for one man to deal with.
This, however, is my favorite part. I think the truck is effectively keeping this valuable lock from being stolen!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-21-2017, 11:00 PM   #13
randy500
That's not even a god parts truck, buy something better, at least something mostly original without all the primer, bondo, holes and wrong parts everywhere you look. Honestly each and every picture has multiple problems shown.
randy500 is offline   Reply With Quote
Old 02-21-2017, 11:07 PM   #14
jocko
jocko's Avatar
Ok, after seeing the second round of pics, I'm going to change my recommendation to "run faster".
Glad you asked. I'm no expert, but I've looked at enough of these trucks to know when to fold em, as they say. This truck is not a good buy at any price. Parts rig maybe - but NOT if you don't have the truck you're going to buy yet - the truck you eventually buy may not need any of these parts, and you'd be paying someone $50 to tow it away eventually. Regardless, whatever you spend on it is that much less you can spend on the next one that may have all its parts anyway. My 2c. I'd punt.
Old 02-21-2017, 11:30 PM   #15
bigrigpardo
well I will throw the only positive thing in the post. if its a real short bed and not a cut down the rolling frame which looks damn decent has to be worth what 500-750? and that motor even if good or not isn't original.
bigrigpardo is offline   Reply With Quote
Old 02-21-2017, 11:46 PM   #16
James the III
That is ruff for a texas truck..BUT..
If you can get it for a song.. I'd get it running and that is it,,, drive it..
buy a better truck with less rust.. and rebuild that.. when it is done..
you can either park this one or sell it.. As a frame off build will take a few years , and one can slowly get better parts for this one as you drive it and go hunting for parts for your full build..
if this is more than few c-notes I'd walk..
bonus it can be a parts hauler while you building the good one.. it's always good to have a truck you don't care about when you are junkyard crawling or swap meat buying..
James the III is offline   Reply With Quote
Old 02-21-2017, 11:47 PM   #17
randy500
Ok, I modify my answer, I see from the pictures that it appears to be a real short bed and looks like original 6cyl truck from the engine mounts. Could be worth saving if you bought a clean donor truck for the body change then you would have the problem of the cab VIN not matching the frame, you could fix that I guess.
Old 02-22-2017, 12:23 AM   #18
1968aj
if you really want a short bed there are options. you can still buy a decent longbed in Texas pretty cheap. there is a guy here in Houston that can make it a shortbed. he can even cut the bed and they come out real good. shortbeds are getting pricey around here and harder to find. honestly I have given away better trucks than this one.
Old 02-22-2017, 10:18 AM   #19
RenoKeene
Florida Edition
RenoKeene's Avatar
It looks like a decent frame, that all it is. $500.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-22-2017, 10:35 AM   #20
DT1
DT1's Avatar
I'm going to go out and kiss my truck right now!
DT1 is offline   Reply With Quote
Old 02-22-2017, 10:45 AM   #21
Grumpy old man
Grumpy old man's Avatar
I'd buy it and even go to $1,000.00 as a parts truck . or a long term builder the frame and vin tag cab/ title are worth $750.00 so you go from there . I buy trucks like this all the time in the $5- $1,000.00 range given they are true short beds with a clean title . But I have all the equipment/tools/TIME/and dry space it takes to bring one back . If you have plans of paying someone else to do ANY of the restoration ...FORGET IT ! it would be a money pit You could spend 2-3 years just finding parts unless you enjoy paying high retail for reproduction stuff . Good original drivers doors are regularly selling in the $500 to $800. range to bring this one back to nice daily driver condition .......$15,000.00 plus and thats with you doing 90% of the work .and the prices will continue to climb just like the "elusive " early model Camaro's did 20 years ago and their still dragging those out of the weeds
As many have already said "it's cheaper to buy one already done or an unfinished project that's close to done "
The big question is what do they want for it ?
Grumpy old man is offline   Reply With Quote
Old 02-22-2017, 10:47 AM   #22
B. W.
B. W.'s Avatar
You beat me to it! The owner is actually worried about some one stealing this truck?
B. W. is offline   Reply With Quote
Old 02-22-2017, 11:09 AM   #23
weq92f
weq92f's Avatar
I'll pile on. Definitely look for a better starter/build truck ( less rust ). This one is probably too far gone. Looks to me like there will be rust under the dash and in the cowl area too. You don't want that.
If you could get it for less than a grand, the motor runs, the tranny is good and it will roll under it's own power, then picking it up as a driver only might not be a bad plan. You'd probably spend another grant on it just making it safe for the road.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-22-2017, 12:18 PM   #24
ken4444
Everyone has posted a wealth of knowledge. The comments are all very much appreciated. I don't have the space to do any kind of project that would require buying 2 or more parts trucks in order to build a project. Even disassembling and rebuilding one truck is going to be difficult. I can kick my wife's F150 out of the garage on occasion, but that's not ideal. Of course that's a different thread.
The seller is ready to get rid of the truck and he has literally asked me what I would be willing to pay. The seller's had some potential buyers come and go and I think I may be his best prospect at this point.
I would have to rent a trailer for about $100 to get the thing home, but a neighbor has a great tow rig and I'd probably buy him a tank of diesel for his time and trouble.
I can envision buying the thing, putting in $1000 to make it safe to drive, but then what? I can't see trying to flip it just to make a few bucks.
One scenario is I buy the thing, find out how truly rotten it is, and end up with a garage full of parts that I don't have room for. That's not ideal.
Reading the comment that someone has given away trucks better than that makes me think that I should not buy this truck just because it's cheap. It will only end up being a pain in the ***.
I do really enjoy repairing old things, but more than once I've gotten into a situation where I felt I was in over my head. As someone pointed out, if the cowl is rusted, then it could mean a whole lot more work.
I'm still on the fence here, but the logical side of me says too listen to everyone and hold out for a better candidate.
Old 02-22-2017, 12:22 PM   #25
davepl
davepl's Avatar
I passed on a "make two cars from one" project this year because of space, and I have a fair bit of it. But I found taking my truck apart for my own frame-off there were times I needed 3 stalls, and it'd be worse if there were 2 vehicles!
Here's one piece of serious advice: buy the best truck you can afford to start with. These trucks are usually worth a lot less than the labor it takes to get them that way, so any money you save by starting with a better unit is usually a savings compared to getting a rougher truck up to that standard.
Here's what I started with. It was $6500 which isn't cheap, but it was complete, no rust, buckets, console, AC, and tons of optoions. It was a California one-owner truck, and was totally complete and unmolested except someone had added a CB radio antenna and an e-brake warning light. Otherwise it was totally originally and just gently worn from new.
Now if you can't swing that, get the 6-banger regular bed version of it, which should run 1500 or so maybe. And that extra $1000 will buy you a TON of progress, even if you were to do a frame-off, because it's complete. You'll spend way more than the $1000 difference just rounding up the missing parts from the truck in this thread.
Here's a pic of what I started with and where I ended up, and I bet from 20 feet away in a pic it's hard to see much difference... And that's partly my point - buy a truck that doesn't look wasted in the pictures :-) Solid driver but worn is a good place to start.
PS: Per everyone's suggestion, I have since put the original wheels back on so it looks even more similar!
