Old 02-22-2017, 12:16 PM   #1
53lowdown
Junior Member
53lowdown's Avatar
Rear Axle Assembly swap - trackbar mount
62 C10 with Eaton. Swapping in an Axle assembly from a 96 Camaro this weekend.
I need to swap the track bar mount onto the new axle. Wondering how others have done that so that it ends up being in right location?
Do I install the axle, center it, and then weld the bracket on? I don't like to weld upside-down and backwards.
OR, do I need to create some kind of jig to hold it in the correct place and weld it on prior to install? Would like to do it this way, but can't picture how to create the jig
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 02-22-2017, 02:49 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Rear Axle Assembly swap - trackbar mount
Honestly I would use an aftermarket "long" track bar (like from Early Classic, super bar) which goes from the frame mount to the pass side trailing arm. This eliminates any welding on the axle and works better than the shorter stock bar setup.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 02-22-2017, 03:23 PM   #3
PGSigns
PGSigns's Avatar
When you weld it weld in short sections and let it cool. Dont weld it all at one time because it will pull the tube around and can mis-align the ends. I second the long track bar.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-22-2017, 03:35 PM   #4
53lowdown
Junior Member
53lowdown's Avatar
I like that idea. The Early Classic one is for 65-72. If I could find one for a 62 I might go that route.
Old 02-22-2017, 03:42 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
http://www.classicperform.com/Store/...k/6062DTBK.htm
Old 02-22-2017, 06:34 PM   #6
53lowdown
Junior Member
53lowdown's Avatar
Thanks for the info - I ordered the long trackbar for 60-62 from CPP.
Old 02-22-2017, 07:03 PM   #7
PGSigns
PGSigns's Avatar
CaptainFab has the correct saddles to weld on to the new housing. Look in the 60 to 66 for sale section for any of his ads and send him a PM.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-12-2017, 03:38 PM   #8
53lowdown
Junior Member
53lowdown's Avatar
Trailing arm mounts from CaptainFab worked great.. CPP Trackbar, not so much. The trailing arm mount for the trackbar won't allow the shock to connect. See attached. Had to trim the CCP trailing arm mount to clear.
Old 03-12-2017, 06:30 PM   #9
PGSigns
PGSigns's Avatar
That is the mount for 63 and up. The one for 60 to 62 is shorter than that one. Look at the box they sent it in and see what it says.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-12-2017, 10:59 PM   #10
53lowdown
Junior Member
53lowdown's Avatar
Box and invoice both say 60-62
Old 03-13-2017, 07:07 AM   #11
PGSigns
PGSigns's Avatar
Looks wrong and not the same as what is pictured on the site. Now the fun starts dealing with their customer service.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-14-2017, 05:03 PM   #12
53lowdown
Junior Member
53lowdown's Avatar
Yeah - I made it work - didn't want to go through the hassle of shipping back and waiting. A warning to anyone else doing a 60-62 though. Make sure CPP sends you the right trackbar mount before you tear down. Odd thing was they sent the right length trackbar, but the wrong mount.
Good news is I'm back on the road with 308 gears - I can drive 70 all day now!
