02-22-2017, 04:24 PM | #1 |
Thoughts on new GM Crate Motor
A while back I posted a thread asking for some opinions on which way to go with my needed engine correction/upgrade. Long story short, The motor in my truck is fairly fresh. However, when the previous owner had someone rebuild it. They "in my opinion" put way too big of a cam in it. Sounds like a built Harley, but has very little idle vacuum and just really doesn't impress with power until you really start to wind it up. It is a one piece rear seal block with World Products Stock replacement heads.
I 'WAS' considering a new top end kit for it, or going with a new 383 long block. The 383 long block that I really want is pricey at $6,000. And I have not found the right top end kit plus honestly don't want to deal with Cam break in and lifter adjusting issues. Soooo.. Fast forward to the present. I see that GM is going to be offering this beauty very soon. http://www.chevrolet.com/performance...-357-base.html I'm thinking that this might be more in line with my budget. I've seen some online pricing suggesting that this new 350 is going to be in the $3,500 range retail. I could build something similar using my block and crank. I do have a one piece rear main seal block, so the potential is there for a Hydraulic Roller, but I do not think that they put a roller cam in there when it was rebuilt. I would prefer a roller cam due to the power curve they can produce. Adding up the components separately (vortec heads, cam, lifters, cam spider, push rods, etc.) I would probably be well over $2,000. Still quite a bit less than $3,500 but I don't really get excited about the thought of rebuilding engines these days. Call me lazy, chicken, or what ever. I honestly like the thought of simply torqueing down an intake and using my existing carb. My truck is a short box 4x4 with five inch lift and 33's with 3.73 gears. None of that is going to change. So, to all those with way more knowledge than I have on these sort of things. What is your opinion on this new GM crate 350? Did they use the right cam, right heads? any changes you would make? |
02-22-2017, 04:29 PM | #2 |
Re: Thoughts on new GM Crate Motor
It's interesting that the spec sheet only shows torque above 3,000 RPM.
That's a lot of torque, as long as it kicks in low enough for your application. |
02-22-2017, 04:40 PM | #3 |
I posted about this motor a few months ago. Most of the users here blasted it due to their ability to build one cheaper in their garage.
1982 K10 SWB 1987 V20 - Sold - Doh! |
02-22-2017, 05:02 PM | #4 |
Is your motor is in good shape overall?... and simply down on power...or more importantly torque?
Ok, this wouldn't be the first time the wrong decision was made in choosing/putting a 'thumpity thumpity' nice sound cam in a heavy vehicle. Cams that sound like that...in a small block motor....make very little torque under 3500 rpm....and this problem is legendary for many. This is not the cam to have in a heavy 4000lb vehicle....(and definitely if you run oversize tires and combine that with a single plan intake manifold...not that that is necessarily the case here) Call a quality cam manufacturer and give them your truck specs (engine, vehicle weight, tire size, etc, etc) and they will get you the correct cam and lifter set for that truck. I think what will get you moving (quickly) will be a cam that has more lift than duration (...which is the thumpity thumpity cams). Call a cam manufacturer and simply talk with them...they can be of immense assistance. Then you won't have to spend big bucks for nothing....and you will get your power back...and probably a lot faster. My two bits. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
02-22-2017, 05:04 PM | #5 |
I'll have to read the other thread, but... that is a bunch of $$.
My vote is go with option #2 ( build what you have ). Take your existing components to the right machine shop, tell them what you want and they'll quote you up, probably well below 3500. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-22-2017, 07:16 PM | #6 |
I guess taking it to a shop is another option. Finding one I trust is another thing I guess. The guy I bought it from and they built him what is essentially a race car motor. I guess $3,500 is a lot of money. However just the heads, cam and lifters would be around $1,800. Figure in maybe new valve springs other necessary parts to go back to a roller cam and your well into $2,000. That's before labor. So maybe I'd be into it for $2,500 or so for the same long block if I use my short block.
02-22-2017, 08:03 PM | #7 |
I would just replace the cam with something more drivable.
Are you sure the World heads aren't vortec style heads. I am vaguely familiar with World Products and I haven't seen anything that I would call stock from them. Anyway it sounds like you have a good motor that just needs the right cam. Get a cam for low end torque and you wont think it's the same motor. How much stall does the torque converter have? You don't need much stall with a high torque low rpm cam. |
02-22-2017, 08:24 PM | #8 |
motor exploder
They didn't build a race car motor if it's got World Products SR heads on it. If I were you, and the motor is healthy, just put a cam in it that suits your needs. If you're not worried about the money, put a nice hydraulic roller in it - being a 1pc rear main block it may have a hydraulic roller in it now(?) and you can reuse the lifters and possibly pushrods.
Do you have any idea what cam is in it now - did the guy you bought it from put a flat tappet cam in it? edit: I checked out the link you posted, that SP350/357 seems like a nice streetable motor.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 02-22-2017 at 08:36 PM. |
02-22-2017, 08:26 PM | #9 |
World Products make a stock replacement head that can be used in place of true stock gm cast heads in some racing classes. That's is what I have. Supposedly similar to the camel hump heads for performance. I'm sure the right cam would wake the thing up. I just have no idea where I'd end up torque and hp wise. Don't want to spend the money for a cam only to be dissapointed. I think I'd like to be around 400 ft lb of torque. My stall is probably around 2,500.
02-22-2017, 08:37 PM | #10 |
02-22-2017, 08:43 PM | #11 |
Unless the heads have huge unwieldy runners, I'd just swap in a reasonable cam. Done in about 4 hours for a couple of hundred dollars.
Then if you don't like that, buy a crate motor, but I bet you can get away with just a cam swap. Heck, pick the cam that comes in the crate motor, so it has the same "brains", and will act and drive largely the same way.
02-22-2017, 08:54 PM | #12 | |
02-22-2017, 09:19 PM | #13 |
motor exploder
I actually think the 400# tq number and 350 hp (or very close) are achievable, with the right cam if your motor is healthy and doesn't have any issues that wouldn't let the proper cam do it's job. I think something in the 214-220* @ .050 range would be okay (talking hyd roller). The GM HOT cam is a good, proven performer and it's 218* @ .050" The SP350 motor you posted uses a 215* @ .050 cam. Not trying to turn this into a 'recommend a cam' thread, but just wanted to throw that out there.
In a little bit different situation, my '05 GMC crewcab 1/2 ton (see sig) weighs 5200# with me in it, 32" tall tires, 3.73's and a little 5.3 engine - I have a comp cams 215* cam in it (265 advertised duration) with a 2600 stall yank converter and it runs very well - and it also pulls my 20' enclosed car hauler just fine. Yes it's a different style motor, but the same principles apply.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-24-2017, 08:44 PM | #14 | |
Find out what type cam it has. If it is a roller hydraulic it would be easy to swap a smaller cam. I'm in no way a cam expert but something in the .440 to .460 lift range should get you good low end torque. |
02-25-2017, 10:05 AM | #15 |
Does anyone have any experience with Comp cams Xtreme 4x4 cams.
If I decide to use my short block and add a cam and heads, I am considering this one. http://www.compperformancegroupstore...ode=RLERCAM4X4 It looks to have similar characteristics as the one in the GM 350/357 crate that I first mentioned. I'd either top it with some Vortec heads or maybe something with just a little more performance capability. |
02-27-2017, 03:00 PM | #16 | |
I had not heard of this new offering but it certainly makes sense. I could never pull the trigger on the 330 HP Vortec 350 because of the flat tappet cam. I will be looking with great interest at reviews of this new engine once it hits the market.
