Old 02-22-2017, 04:24 PM   #1
3+3 1Ton Dually
5 bolt disc hubs to 6 bolt disc hub swap
I'm working on a rwd 1968 C/10 Panel Truck that has had the drum brake front suspension swapped out with a 1974 C/10 disc brake power steering front suspension. I would like to swap the 1974 5 bolt hubs back to the 1968 6 bolt hubs and am wondering if anyone has done this and what parts would fit?
Thank you!
Nothin' but time!
3+3 1Ton Dually is offline   Reply With Quote
Old 02-22-2017, 05:15 PM   #2
SCOTI
SCOTI's Avatar
Re: 5 bolt disc hubs to 6 bolt disc hub swap
You can use aftermarket 6-lug conversion hub/rotors instead of the factory disc brake 5-lug hub/rotors. You will need 6-lug disc brake spec wheels though. Factory 68 6-lug drum brake wheels won't clear the calipers.
Classic Performance Parts
Early Classic Enterprises
Performance On Line
Summit Racing
McGaughy's
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-24-2017, 02:27 PM   #3
SS Tim
SS Tim's Avatar
Lots of information in this thread
http://67-72chevytrucks.com/vboard/s...68&postcount=4
SS Tim is offline   Reply With Quote
