Old 02-22-2017, 04:26 PM   #1
Marcus4800
Upper A frame question
Where the upper A frame attaches to main truck it has two larger nuts on each end that has a grease fitting in each of them The rubber boot is missing on one of them. Can I just remove the nut with grease fitting and slide a new rubber boot on or do I have remove the whole A frame to do it? Thanks for your help..
1963 C10 Shortbed
Marcus4800 is offline   Reply With Quote
Old 02-22-2017, 05:46 PM   #2
kerber63
kerber63's Avatar
Re: Upper A frame question
I don't think there will be enough clearance to slide a new rubber seal on the shaft through the control arm. I would take the upper arm off and replace the whole shaft (unless it's been recently done). New shaft kits are pretty inexpensive. Use lots of penetrating fluid on the steel bushings, if they're rusted in and you wipe out the threads you might be looking at replacing the control arm too.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
