![]() Join Date: May 2002
bolt specs for rear trailering arms
working on a 69 chevy with coil spring rear, and am having trouble locating the bolts that hold the rear trailering arms to the frame. so, i figured i'd go to lowe's or home depot and see about getting those bolts, but i don't have the old ones to compare. anyone have the specs of these bolts? i think that they are 3/4" X 5" with 18 ct thread pitch. most appreciative. thanks
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
![]() Join Date: Sep 2001
Oh man....I don't remember. Sheesh.
I got mine at Lowe's, but I have to warn you. That stupid store has decided to greatly reduce their fastener section recently. When Eagle was still in business before they were bought that's the only reason I went to that store. Now... Try Tacoma Screw. They're a good company (local), but they have a national 1-800 number. You can get just about anything from them if you order it. LMC will sell you them, but they're not grade 8. At least they'll have the specs. I could measure mine and get back to you....
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
i was afraid that that would be a problem. last time i was in there, though, they didn't have any grade 8 bolts big enough for what i was doing. anyhow, there is a fastener place close to here that i could try, but do you think that they would have that bolt, even without me telling them the specs?
i saw that LMC sells them, but i didn't trust that they weren't grade 8. if you wouldn't mind measuring it, i would appreciate it very much. thank you
Cantankerous Geezer
You need 3/4-10 X 4" bolts, grade 8. You can get them at farm stores, hardware stores that cater to contractors, and fastener stores. I bought mine at a farm store, they sell by the pound, and are a lot cheaper than the hardware store. Your profile shows Houston, you shouldn't have any problem finding them.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
cool. thanks fred
