02-22-2017, 11:44 PM | #1 |
Hood hinge question
I have read every thread on the subject. If you have bought after market hood hinges and you are satisfied, could you please tell me where you bought them??? No info needed on how worthless they are and "you should buy original or used original". "Have yours rebuilt" etc...
Trying to keep this simple. Thanks in advance! |
02-22-2017, 11:55 PM | #2 |
Re: Hood hinge question
Can you point me to the threads on this subject?
02-23-2017, 09:00 AM | #3 |
No experience on my end with the hinge replacement or rebuild. I have read more folks are happier with them rebuilt than aftermarket. Seems to be ONE real good rebuilder out there for old hinges, can't recall his name or site at the moment, does a lot of Chevelle work on their forums.
I had a real tough hinge to open/close on my '68 GMC and read where this guy recommended some spray called Deep Creep by Seafoam to use until you get them rebuilt. Doesn't fix the hinge but really makes it work better. I can lift my hood with a couple fingers now. |
02-23-2017, 10:39 AM | #4 |
motor exploder
I'm using Ringbothers hood hinges on my '69 C10. They operate nice and smooth, no issues.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-23-2017, 01:04 PM | #5 |
Old member
Willie is his name and hinges is his game!
Guy's can say what they want about the billet hinges but when it comes to the originals Willie is the man! Billets are nice and all but if your truck is a driver then originals are fine. http://www.hoodhingerepair.com/
02-23-2017, 04:26 PM | #6 |
I picked up a set of new repo ones and springs from the truck shop in orange. Put them on and they work perfect. No complaints except trying to install the spring. Guess I'm not as strong as I use to be.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-23-2017, 04:39 PM | #7 |
I have a stock set that are about to hit the trash can. You can have them if you want, just pay the shipping. They are off my 1967. I have Nates on mine now.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
02-23-2017, 08:38 PM | #8 |
x2 on Willie, he make your original hinges just like new.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
