Old 02-23-2017, 03:38 PM   #1
Hobbit
Hobbit's Avatar
What is a good cam
I'm rebuilding my 1972 350 and wanting to stay close to stock with a slight upgrade.Does anyone know the factory spec on the cam and i'm going to flat top pistons .030 over and looking at speed pro cam what should i go with?
Hobbit is offline   Reply With Quote
Old 02-23-2017, 05:29 PM   #2
demian5
demian5's Avatar
Re: What is a good cam
Call crower cams and ask. Can't go wrong there.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-23-2017, 05:37 PM   #3
coreyjhen
The generic parts-store replacement cam has .390/.410 lift and 194º/202º duration. The 204º cam is a nice mild upgrade.
coreyjhen is offline   Reply With Quote
Old 02-23-2017, 07:54 PM   #4
James the III
Are the heads stock to that 72 350?? don't guess.. run the numbers..
what cam you use on a flat top 355 and head chamber cc. will make or break it..
it is easy to get the static compression and dynamic compression to high with flat tops and iron heads.. and a stockish cam..
make sure you know what heads they are, don't guess run the casting #'s
James the III is offline   Reply With Quote
Old 02-23-2017, 08:23 PM   #5
BROWN 70
BROWN 70's Avatar
I,ve had very good luck with with the sum-1102. good mpg and nice low end torque. works good with 8.0-9.0 comp. BROWN 70
BROWN 70 is offline   Reply With Quote
