Old 02-23-2017, 09:29 PM   #1
dave`12
dave`12's Avatar
Gas pedal question
My 67 has an interesting gas pedal, two ball studs at the bottom hold the pedal to the truck, and it slides at the top.
With the new carpet, I can't get the pedal to stay on the balls. I'm wondering if anyone here has adapted a different type of pedal, one that does not rely on a mount at the bottom.
If so, I would be interested in how you did it.
dave`12 is offline   Reply With Quote
Old 02-23-2017, 10:08 PM   #2
Dustmaker65
Dustmaker65's Avatar
Re: Gas pedal question
Not a ton of help....but you can switch over to a '71-'72 pedal/cable assembly. It takes a little work, but will work.
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 02-23-2017, 10:08 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Here is one thread on it....
http://67-72chevytrucks.com/vboard/s...d.php?t=669995
There are a lot of threads on the subject.
LockDoc
Leon
Old 02-24-2017, 11:21 AM   #4
dave`12
dave`12's Avatar
Thanx, I will try to find some of the other threads, did not think of that. Was hoping for a quick, not replacing the whole thing trick
Old 02-24-2017, 11:34 AM   #5
LockDoc
LockDoc's Avatar
I don't think there is an easy answer. You might try replacing the ball studs to see if that helps, but that is not always an easy task either. If you don't heat the old ones before trying to remove them they often twist off and have to be drilled out and the holes re-threaded.
LockDoc
Leon
Old 02-24-2017, 01:42 PM   #6
davepl
davepl's Avatar
Sometimes the carpet is just too bushy around the balls and you have to trim some back.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-24-2017, 03:16 PM   #7
Fraud
Fraud is offline   Reply With Quote
Old 02-25-2017, 12:08 AM   #8
El Dorado Jim
x2, change to the 71-72 cable type throttle linkage...
El Dorado Jim is offline   Reply With Quote
Old 02-25-2017, 08:13 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Gas pedal question
Best money you will spend on a gas pedal assembly.
http://67-72chevytrucks.com/vboard/s...d.php?t=689764
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-25-2017, 11:22 AM   #10
weq92f
weq92f's Avatar
sometimes the carpet is just too bushy around the balls and you have to trim some back.
lol
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-25-2017, 04:09 PM   #11
El Dorado Jim
Originally Posted by weq92f View Post
lol
Ha Ha I missed that, that is Funny!!!!
Old 02-27-2017, 09:15 PM   #12
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Welded this late '70s early '80s firebird/ trans am unit to the original lever and it works flawlessly. Well it has for 349,000 miles so the test drive continues.
CaptRMW is offline   Reply With Quote
Old 03-03-2017, 02:32 PM   #13
dave`12
dave`12's Avatar
I like that Capt. I was just about to pay 50.00 for the kit, I'm gonna look for a way to duplicate yours before spending the money.
Old 03-03-2017, 07:37 PM   #14
dennislbrooks
dennislbrooks's Avatar
I like that solution also captrmw. In my case I would have to check on how to make the old mounts not noticeable with my existing carpet.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 03-03-2017, 08:07 PM   #15
dave`12
dave`12's Avatar
And I will have to find an old gas pedal..
Old 07-27-2018, 02:55 PM   #16
dave`12
dave`12's Avatar
Finally got around to this. It's a project and just now getting to where I'm driving it. Followed Capt. RMW's lead and bought a used gas pedal on Ebay (8.00, from a 70 Barracuda). I think that's pretty cool in itself.
Well, got it welded, and the test drive is underway
1967 C-10 4-speed, 350v8
Old 07-27-2018, 03:05 PM   #17
69Tex
save your time and money, take a small box cutter to where the balls are and cut them through
69Tex is offline   Reply With Quote
Old 07-27-2018, 04:45 PM   #18
weq92f
weq92f's Avatar
lol again
Old 07-27-2018, 09:55 PM   #19
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Looks good Dave, I am still "road testing" mine after 29 years and 480,000 miles. We are in Deming,N.M. on the last third of an 8500 mile trip.
Later, Capt. Roger
Old 07-28-2018, 12:14 AM   #20
dmjlambert
dmjlambert's Avatar
Oh man, I just saw this right after I trimmed the bushiness from my balls on my 69 truck and installed the pedal onto the new carpet. I should have been paying attention and done it this better way. Yes that does look very nice, both of you.
dmjlambert is offline   Reply With Quote
Old 07-28-2018, 02:34 AM   #21
Rufas
Rufas's Avatar
Exactly what I did. I have Dynamat Sound Insulation, 1/4 inch sound deadening foam and about 1/2 inch matting under the carpet.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 08-22-2018, 10:36 AM   #22
67chevemall
67chevemall's Avatar
This is brilliant. If mine falls off one more time it is out the window
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-23-2018, 08:21 AM   #23
72LB
72LB's Avatar
Thanks for the idea! I'm going to look for another pedal next time I'm at the pick-n-pull.
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 08-25-2018, 11:46 AM   #24
turp mcspray
turp mcspray's Avatar
I have come across this a few times, I simply remove jute, from the pedal area of the carpet, and problem is solved.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
