Old 02-24-2017, 06:53 PM   #1
Yaboyolin
Yaboyolin's Avatar
Drive not engaging
Hi guys, my trucks up and running, sorta, still have some kinks to work out like brakes and an oil leak and a thermostat leak but none the less it's running. Anyways. It was completely out of ATF so I filled the transmission up with that and went to put it in drive to no avail. It sometimes kicks in but it's not spinning the driveshaft. Reverse works and everything. Just Drive, L2, and L1 aren't working. The truck sat for years. Ideas? Solutions?
If someone from the future doesn't come back in time to stop you, it can't be that bad of an idea
Yaboyolin is offline   Reply With Quote
Old 02-24-2017, 07:12 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Drive not engaging
Possibly still low on fluid..... My TH350 had a slow leak and if it was down just 1/2 quart, it would sometimes slip (briefly not engage) going forward from a stop.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-24-2017, 07:33 PM   #3
Yaboyolin
Yaboyolin's Avatar
Fluid is full. My guess is it's the clutch for the drive gears, is that pretty accurate?
Old 02-24-2017, 08:23 PM   #4
wbc409
Most likely clutches. Very high probability the tranny will need a rebuild.
wbc409 is offline   Reply With Quote
Old 02-25-2017, 12:40 AM   #5
Rochlow
I had issues with the internal shift linkage on my TH350. I had to drop the pan and tighten one bolt. Fixed
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 02-25-2017, 09:47 AM   #6
turbosix
turbosix's Avatar
If I remember correctly, the TH350 uses the same clutch pack for 1st and reverse so I would look a the linkage. It could also be the forward clutch pack. Since it has set for a while you might could try a seal softener first.
Tommy
1 Pt. 3:21
'72 C10 LWB 402
turbosix is offline   Reply With Quote
