02-24-2017, 09:43 PM | #1 |
700R4 Clunking and slipping
I'm quite worried about this.... I've got a 700R4 with a real mild shift kit. It backs a Ramjet 350. So it's 351 horse and 403 torque. It has just recently started to slip- the engine keeps running and slowly revs higher and the tranny finally catches up (it takes about 1-2 seconds) and it surges forward. Not a real firm jerk but a quick pulling as if I hit the gas a little harder than usual. I hope I'm not losing a tranny. Any help? Thanks guys!
02-24-2017, 10:18 PM | #2 |
Re: 700R4 Clunking and slipping
Check tv cable adjustment and not drive it until you do
02-24-2017, 10:27 PM | #3 |
What is the TV cable? Sorry I'm new
02-24-2017, 10:43 PM | #4 |
Its the cable that controls the line pressure and proper shifting of the 700r4. It runs from the trans to the carb and depending on which carb a specific bracket could be needed for proper geometry of operation. Post a pic of the drivers side of your carb that may be of some help
02-24-2017, 10:48 PM | #5 |
It's got a ramjet efi system. The linkage is on the passenger side. I can post a picture tomorrow.
02-24-2017, 11:57 PM | #6 |
Have you checked the fluid?
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
02-25-2017, 12:26 AM | #7 |
Yep! It looked full, maybe a tiny tiny bit high. It was pink. Smelled okay too.
02-25-2017, 04:44 PM | #8 |
Hopefully it's one of these cables!
02-25-2017, 05:06 PM | #9 |
Would also need a pic where it connects to throttle body but that bracket doesn't look like any ive ever seen and looks like it could shift back and forth if its only bolted by one bolt. And that would be a big no no with a tv cable on a od trans.
