02-25-2017, 12:06 AM | #1 |
Needing help on electric fan
Hi all, just about finished up getting my truck running it has been challenging for me but I came through. I'm needing help on installing the electric fan I was going to buy a fan harness but it don't come with a temp sensor ? Any ideas on where to start. 1959 Chevy Apache with a 5.7 vortec from a 1997
Posted via Mobile Device |
02-25-2017, 10:54 AM | #2 |
Re: Needing help on electric fan
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
02-25-2017, 12:50 PM | #3 |
That Jegs kit is about as simple as it gets.
The ground side of the relay coil goes to the temp sensor. There are a couple different ways to set it up depending on application. With your AC it can complicate things a little. I would suggest finding a relay with NO/NC contacts. You can hook AC circuit to the 5 pin relay, putting the temp switch on the NC contacts. That way when the AC sends a signal to the fan, it opens up the Temp controlled circuit, and there is no backfeeding. https://www.delcity.net/store/5-Pin-...racket/p_73576 Last edited by whitedog76; 02-25-2017 at 12:58 PM. |
02-27-2017, 03:55 AM | #4 |
I have a brand new Jegs-type kit I'll send you for $10. Only trouble is a 165-175 fan switch.
03-05-2017, 10:11 PM | #5 |
I have that same radiator.
I think you will have cooling problems unless you go to a shroud and dual 11" puller fans. |
