02-26-2017, 03:25 PM | #1 |
04 Truck TB -- Which non-truck pedal/TAC can I use?
I have an '04 escalade throttle body. I realize I can use an 04 tac and pedal, but I'd rather go with something that looks nicer and is a bit more low profile. I read that a re-pinned Corvette pedal would work but haven't seen any solid confirmation of what other pedal options there are.
Anyone have experience they can share? Thanks in advance!
1968 LWB C20 / AC / Wood Bed |
02-26-2017, 05:16 PM | #2 |
Re: 04 Truck TB -- Which non-truck pedal/TAC can I use?
I read just now in "How to Use and Upgrade to GM Gen III LS-Series Powertrain Control Systems" that the 1997-2004 Corvette and 2004-2005 CTS-V pedals have the same output. So, I think the CTS pedal is another option I may consider.
However, now I'm rethinking the use of the truck pedal; since it's got a metal arm, I could modify it more easily to have whatever ergonomics I want...
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 02-26-2017 at 05:24 PM. |
02-26-2017, 11:55 PM | #3 |
What's wrong with a truck pedal? Sounds like you're creating a problem that doesn't exist. There are enough challenges in a build, no need to create another. Using the stock truck pedal with stock bracket is an easy bolt on that preserves the stock parts the engine was intended to use.
02-27-2017, 05:08 PM | #4 |
That pedal does look nice, what year is it from? I've been looking at pedals with metal arms which I like because they could be repositioned but yours does look well-placed there...
02-27-2017, 11:32 PM | #5 |
It's specifically from an 06 Silverado but we have an 08 Tahoe and it's the same exact setup. (PN: 15107594) Make sure you get the bracket to go with the pedal, makes the install super simple.
02-28-2017, 10:03 AM | #6 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
